Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 07-28-2002, 02:35 PM   #1
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
pump not working...
looks like the original. the motor works fine when I throw the switch on the control panel...belt turns ok...actuator arm goes up and down....but no water comes out of the sink. This looks original...(73). Any point trying to fix it, or should I just replace it. I see in the camping world catalog, there are a wide range of pumps/prices. what do I need? owner's manual says that the pump supplies 3 gpm.
The previous owner's never used it, I don't think. They had it for 6 years, and didn't have a key for the fresh water tank filler. they only went to campsites with full hookups, so god only knows when this thing last pumped water.....
Chuck is online now   Reply With Quote
Old 07-28-2002, 02:45 PM   #2
74Argosy24MH
Profile:  LOST , Hawaii
I vote for replace; replace the rubber hose with vinyl or plastic and clean the heck out of your fresh water tank.
Clean fresh water tank
John
74Argosy24MH is offline   Reply With Quote
Old 07-28-2002, 02:48 PM   #3
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Pump
I would replace it unless you are a stickler for keeping everything in the trailer original. The new pumps are typically quieter, self-priming, and run dry without damage.
As far as new pumps go, price is probably more a indicator of quiet operation and smooth flow than it is build quality. Even the lower priced pumps seem very reliable.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 07-28-2002, 09:13 PM   #4
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
CampingWorld.com has several good pumps on sale.
http://www.campingworld.com/browse/s...3&skunum=20066
http://www.campingworld.com/browse/s...10050&src=UPSE
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 07-29-2002, 07:03 AM   #5
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
thanks, guys. I was just wondering: is there any chance that I'm doing something wrong, here? does the pump need to be "primed" somehow? the owner's manual doesn't say anything about it....I'm wondering if the tank has to be completely full to get it started or something. Probably the internal seals are n-g....maybe difficult to replace, too, but I just want to make sure before I spend $$$. Its not like a pump is all that much money, but I'm nickel-and-diming myself to death, here...
Old 07-29-2002, 07:18 AM   #6
Pahaska
Pahaska's Avatar
Images: 12
Pump prime
Could be the problem. I had one trailer in the past where I had to put close to 10 gallons in the 20-gallon tank to get the pump to initially prime. After that, it would pump right down to empty. It would be worth topping it up to see.
Most new pumps are self-priming, but I'll bet one that old is not.
John W. Irwin
Old 07-29-2002, 07:21 AM   #7
74Argosy24MH
There is a rubber diaphram inside. If it sat dry for 6 years the rubber probably fell apart. That is why I said you should also replace the rubber hose, it is going to diissolve in your water.
I had one of these in a pickup camper. They are sort of noisy, it is self priming, so if you get enough water to cover the hoses it should prime.
John
Old 07-29-2002, 07:35 AM   #8
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I don't want to steer you wrong but that is a Par pump and I believe parts are available for it. Someone on this forum rebuilt theirs and mentioned it a number of months ago. They could probably point you in the right direction for a replacement diaphram if that is the problem. Wish I could be of more help.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-29-2002, 08:54 AM   #9
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Chuck. Overhaul kits are available for the old PAR pumps. The kit comes with valves, diaphragms and gaskets. Unused pumps usually need new valves. Different models have different kits.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 07-29-2002, 09:01 AM   #10
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
When we looked into fixing our PAR pump it was going to cost almost as much as a new pump for the kit and of course, there was no guarantee that it would work with the kit.
We decided to replace/update it with a new ShurFlo instead.
Shari
Old 07-29-2002, 09:47 AM   #11
Fatt Ratt
Fatt Ratt's Avatar
Profile:
PAR Pump
Hey y'all,
I had this same problem on my '72 everyone thought it was the pump. It was a small check valve upstream that the guts had failed and would not let the system prim or pressurize. This problem lets you use shore water, but when you go to use the pump, no H2o or very low volume of H2o comes out of the tap, the pump will be running fine but no H2o.
This problem led the org. owners to sell it to me after they had replaced the pump, pure. filters and the pressure reg. I now have 2 good pumps, great tasting H2o and really good pressure.
The check vlv is easy and inexpensive to fix. On my TT it is located in the bedroom area. - Ray
Cut to suit, Beat to fit, Paint to hide!!
Fatt Ratt is offline   Reply With Quote
Old 07-30-2002, 02:40 PM   #12
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
Ray,
is this check-valve supposed to seal-off when there's no city water pressure, so the pump doesn't just suck air? I've been trying to visualize how this city/pump system works without throwing a valve somewhere. the input/output lines for the pump just "disappear" under the floor of the trailer....
Your unit is probably exactly like mine. Where exactly was the valve located? under the steet-side bunk? Is it something you can buy at any plumbing supply house, or a special AS part? i'll probably need a pump, anyway, but just in case, I'd like to know more about this.....
thanks
-Chuck
Old 07-30-2002, 04:22 PM   #13
Fatt Ratt
Fatt Ratt's Avatar
Profile:
Check Valve
Hey y'all,
Chuck; I'll try to write it, without confussing you too much.
The check valve keeps the system air tight, when the valve guts fail you have an open system. On my TT I would connect to shore H2o no prblem. What caught my eye was when disconnecting the H2o hose alot of water would run back out of the hard pipe of the TT.
My bedroom floor plan has one curbside bunk and the roadside has a closet and dresser with drawers.
The check valve is located under the closet on the deck. On mine, the pipe comes from the the underside into the compartment and right there is the inline check valve. Was not hard to remove. You have to remove it from the system to inspect it. Mine had all the info still on it so I could replace it. I verified the info with my TT's service book. Install valve with flow arrow pointing fwd.
Plumbing suply store or a TT repair store with a parts dept. will carry this valve. Price under $10.00. Cheap fix if this is the problem. Good luck , keep us posted. - Ray
Old 05-14-2007, 04:53 PM   #14
Jim Weilhamm
Profile:  1974 31' Sovereign
Tallahassee , Florida
water pump wiring
I have a 1974 International. Can anyone tell me how to properly wire the water pump. The water pump is a Par 36800. It appears to have a red relay switch mounted on the front of the pump. I was rebuilding my Airstream and the wire labels were lost.
Jim Weilhamm is offline   Reply With Quote
Water Pump David Hall Water Heaters, Filters & Pumps 8 01-12-2004 09:31 PM
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 05:35 PM
Time for a new demand H2O pump thenewkid64 Water Heaters, Filters & Pumps 14 09-26-2003 02:34 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 11:16 AM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 01:44 PM
