Old 01-16-2014, 07:39 AM   #1
1997 34' Limited
jesup , Georgia
pump location
frozen components i believe. i hear pump running and dont want to start tearing out hardware until i confirm pump location. 1997 34' excella 1000.
your help appreciated
wwhidden is offline   Reply With Quote
Old 01-16-2014, 07:46 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Turn off the pump and give everything time to thaw. If your lucky all will be well
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-16-2014, 07:48 AM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Ours is under the lift up panel in the cedar closet across from the toilet/shower. You should easily be able to access the pump as well as the associated lines.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
