Old 06-29-2010, 05:41 AM   #1
1978 28' Ambassador
Savannah , Georgia
Pump filter cleaning
Looking at pump filter and it is all black inside the clear housing. Noticed some black water coming out of faucet. How do you clean the pump filter? The clear plastic cover turns, but decided I would ask here before I break yet another thing! Thanks for any and all help. Jack
Skamper1 is offline   Reply With Quote
Old 06-29-2010, 06:07 AM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
Jack,
Yes if it is one of those bulb style in-line filters it should swist so you can get to the screen.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 06-29-2010, 06:08 AM   #3
Ottawa , ON
How about getting a new one? Live it up!
Which filter is it? If you don't know, just post a photo...
Old 06-29-2010, 06:18 AM   #4
Lily&Me's Avatar
Normal , Illinois
Yep, ours twists off for cleaning, although not easily. It is appalling what gets past the filters.
Maggie
Old 06-29-2010, 07:27 AM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
It's not really a filter, just a screen to keep big stuff from jamming the pump. If you have black water, you may have bigger issues with your fresh water tank.
mojo is offline   Reply With Quote
Old 06-29-2010, 12:25 PM   #6
Ottawa , ON
Several ideas on sanitizing the fresh water tank in this thread.
But rinse out the black crud first. The fresh water drain is one of those three taps in the recessed area near your sink. Two of the taps are "low point" drains, the third is the fresh water tank. All three empty onto the ground.
Old 06-30-2010, 04:21 AM   #7
1978 28' Ambassador
Savannah , Georgia
Amazing what you can see with a flashlight. The filter is on the inlet side of the pump. There is a screw that holds the cover and "o" ring on to the filter. Removed screw, cleaned all the black stuff off the screen, cleaned up the cover itself, lubed o-ring and reinstalled. Think I need to treat and flush all tanks. Assume it has never been done. Thanks. Jack
Water Filter - 1976 Ambassador campergirl 1974 - 1979 Ambassador 3 07-04-2009 10:02 AM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
A Way To Filter Well Water? Phantom Fresh Water Systems 1 08-23-2007 12:08 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Water filter Rob30044 Water Heaters, Filters & Pumps 2 07-10-2005 10:24 AM
