Old 06-18-2011, 10:03 AM   #1
1988 32' Excella
Anderson , South Carolina
Problems w/water heater '88 Excella
The pilot light is burning, it heats the water in the tank, but when the water runs out it won't kick back on to reheat. In order for it to reheat, you have to keep flipping the switch. Why is it not kicking back on?
dcslater is offline   Reply With Quote
Old 06-18-2011, 10:19 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
More than likely the right hand thermostat, clix on, is not making a connection during cool down of the heater. That should close as the heater cools to call for relighting.
If you have an OHM meter and while the heater is cool remove the 2 brown wires and check for continuity across the thermostat. If it is open that is the problem. Not as likely but also remove the red wires and check that one also. Booth should be close while the heater is cool.
If one is bad replace as a set.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
water heater, 1988 excella
Black Water Light Indicator & Water Heater problems SGM ADAMS General Repair Forum 9 04-17-2012 05:18 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
Water heater problems... kayamtom Water Heaters, Filters & Pumps 9 03-19-2007 05:22 PM
Water heater, toilet problems on a MH zduke4x Water Heaters, Filters & Pumps 2 06-07-2004 03:20 PM
