Old 12-11-2014, 09:29 PM   #1
Problem with dual-source water heater on 2012 International 28'
Lately when we set up the water heater kicks on, but goes off a little later (light comes on and no hot water). A complete electric re-boot always does the trick, but it's a pain. Any ideas? Am I doing something wrong in my setup sequence?
Krusty Buns is offline   Reply With Quote
Old 12-11-2014, 11:15 PM   #2
mefly2's Avatar
2015 25' FB Eddie Bauer
The red light usually means an error with the propane circuit ... are you connected to shore power? You should be able to run on both propane and electric; hence, the two switches ... not sure why you would need to shut down power and bring it up again for the electric side ... could there just be a pause before you detect hot water? If your propane supply is good, then the red light will come on and go off after 1-2 seconds. When it stays on you do not have a lit burner in the water heater.
Old 12-12-2014, 04:17 AM   #3
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
My guess is that the "re-boot" is simply giving the heater a second start cycle and that the second cycle works.
We have experienced problems with the propane side of the water heater when a spider built a teeny tiny nest inside the Venturi tube of the heater. I knew of the possibility of this problem in reading but I was unprepared for the actual small size of the restriction. When I actually removed and found the nest I did not believe I had found the problem. It has been fine since then though.
Just wondering how you re-cycle the heater? Are you just switching off and then back on? Are you using propane or electricity or are you turning on both?
Curious,
Bruce
Bruce B is offline   Reply With Quote
2012 airstream international serenity 30 new unit leather dual a/c units we deal eBay Watch Airstreams on eBay 0 01-21-2012 03:50 PM
2012 airstream international serenity 30 new unit leather dual a/c units we deal eBay Watch Airstreams on eBay 0 01-05-2012 05:10 AM
2012 airstream international serenity 30 new unit leather dual a/c units we deal eBay Watch Airstreams on eBay 0 12-23-2011 02:20 PM
2012 airstream international serenity 30 new unit leather dual a/c units we deal eBay Watch Airstreams on eBay 0 12-16-2011 05:10 AM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
