Old 05-23-2014, 09:52 AM   #1
gatewaygrip's Avatar
1963 28' Ambassador
1967 26' Overlander
St. Louis , Missouri
Pressurized Water System
Looking for suggestions for a 12v air pump for a '63 Ambassador fresh water system. Thanks in advanced for comments.
gatewaygrip is offline   Reply With Quote
Old 05-23-2014, 11:56 AM   #2
SteveH's Avatar
Common Sense , Texas
I know those models of Airstreams used a pressurized tank and water system, but I would convert it to a demand pump so fast it would make your head spin. Everything has used a demand system since the 70's, and it's just a better, simpler system.
Regards,
Steve
Old 05-23-2014, 05:52 PM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Do a search for Grover air pumps.
I have the air pressure system in my '61 and I like it. I don't have to listen to a pump come on every time I run a little water. If my pump quits I can use an external compressor such as the 12 volt pump I carry for tires, so don't have to cut my trip short. And I don't have to look for an air compressor to blow my lines out for winterizing.
Sam
samb is offline   Reply With Quote
Old 05-30-2014, 07:27 PM   #4
1963 28' Ambassador
1967 26' Overlander
Thanks Sam! I'm with you, I really like the pressurized system, it's simple. I still haven't fixed my problem with the compressor. After doing research and cleaning the old Grover, I believe it maybe the DC power.
Old 05-30-2014, 09:41 PM   #5
1974 Argosy 20
Kooskia , Idaho
Most any reasonable volume 12 volt air compressor should do. Good ones can be had at off road 4x4 shops, as they like a good compressor when out in the boonies.
Harbor Freight has a fair size one too, just not sure about the quality over time.
You may want an extra check valve on any compressor as a leak could bring water or water vapor back into the compressor itself, which would not be good.
That said, I am with Steve H on a demand pump as a more practical solution, and it gives an increased water capacity, as there is no need for an initial air space in the tank.
Odd pressurized water system Avion C-10 rockhound66 Vintage Kin 5 05-18-2012 12:23 PM
How To Use Pressurized System tbettes Fresh Water Systems 2 02-03-2012 09:55 PM
air pressurized water system on '63 Safari mmenchel Fresh Water Systems 22 07-26-2010 04:29 PM
Converting pressurized water system to demand.. Is tank vent needed 63air Water Heaters, Filters & Pumps 1 07-05-2005 09:11 PM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
