Old 09-19-2015, 10:16 AM   #1
2012 27' FB International
Boulder , Colorado
Pressure relief valve removal
Our pressure relief valve needs replacing as it is encrusted with deposits. Snapping the valve open and closed does not clear the seal, so it's leaking.
The problem is that it appears that the threads where the valve screws in to the tank have deposits making removal difficult. I can get a long stem plumbing wrench (aka: knuckle saver) on the valve, but I am unable to get the valve to turn. I'm a bit paranoid about really torquing on it and damaging the heater.
Thoughts, advice???
motozen is offline   Reply With Quote
Old 09-19-2015, 10:32 AM   #2
Tuco's Avatar
1988 32' Excella
Ojai , California
Use a heat gun to heat the fitting around the valve then try and remove it.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 09-21-2015, 07:48 PM   #3
Boulder , Colorado
Thanks, I'll give it a try.
Old 09-21-2015, 09:03 PM   #4
Kevin245's Avatar
If the fitting is made of aluminum I'd advise against using an open flame heat source. Aluminum does not react well when heated with a soldering torch or similar tools. The slightest overheating and the material will literally melt away before you can blink an eye.
Eleanor Roosevelt
Old 09-22-2015, 10:39 AM   #5
belen , New Mexico
triflow lubricant for a few days should do the trick
alantbird is offline   Reply With Quote
Old 09-23-2015, 07:48 PM   #6
Boulder , Colorado
Thanks for all your ideas. WD, 10 minutes and a honking wrench did it. Destroyed the old one, but the heater is just fine.
Any ideas on what to do to prevent the buildup of calcium? And considering how the valve was encrusted, would running vinegar into the plumbing and letting it sit for a day help to remove any buildup in the lines and faucets?
Old 09-24-2015, 07:16 PM   #7
Boulder , Colorado
Fill system with vinegar to get rid of calcium deposits?
I took the recently removed pressure relief valve from the H2O heater, which was completely encrusted in calcium, and soaked it for 24 hours in vinegar. I was amazed at how it dissolved almost 100% of the calcium. I tried to post pix, but it would not upload them, even after I shrunk them to the required file size?!?
Considering how it cleaned off almost all of the calcium buildup, I'm wondering if: 1) all of the water lines and valves have calcium buildup, and 2) if filling the system with vinegar and letting it sit for a day would clean it all up, or cause harm?
Thoughts/advice?
Old 09-25-2015, 10:40 AM   #8
2002 31' Classic
Houston , Texas
1. Vinegar works.
2. Leaving it overnight (or for a full 24 hours) will harm nothing. Vinegar is acetic acid, which is only mild.
It works in home water heaters, as well.
KMarshall is offline   Reply With Quote
Water heater pressure relief valve woliners Water Heaters, Filters & Pumps 6 07-10-2008 07:12 AM
pressure relief valve twiggy137 Plumbing - Systems & Fixtures 10 05-13-2008 08:20 AM
Pressure relief valve CBsquidSS Fresh Water Systems 4 03-03-2008 02:43 PM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
