Old 07-11-2016, 07:50 AM   #1
philipsinewe's Avatar
2003 30' Classic
Centerville , Ohio
Precision Temp Tankless Installed
Well, installed a tankless heater this weekend in our 2003 Classic. Thought I would post photos for others to have as reference. Just a short list of things we had to do, issues, etc.
1: Pulling the old tank out was a bit rough, the foam insulation got in the water.
2: Had to cut the opening bigger. Also have to cut the inner wall. We just snipped the inner wall and bent it up and out of the way.
3: Plumbing was fairly simple, see photos, we used push connections.
4: Propane does not reach unit, so we had to add propane line. Not too bad of a job, need a cooper tube flaring tool.
5: In our case, we had to move a shelf under the sink up a bit, which required some rework on the shelf, fairly straight forward.
6: Unit has flanges large enough to cover the whole (old unit is wider than new, height is a little taller than old unit.
ID:	266479   Click image for larger version
ID:	266481   Click image for larger version
ID:	266483   Click image for larger version
ID:	266485   Click image for larger version
Phil and Kathy Sinewe
2003 30' Classic W/Hensley Arrow
2014 F-150
Centerville, OH
philipsinewe is offline   Reply With Quote
Old 07-11-2016, 08:02 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
How are the corners sealed against water infiltration, from the photo the corners appear exposed.
How does it perform?
Kelvin
Old 07-11-2016, 03:51 PM   #3
2003 30' Classic
Centerville , Ohio
It has corner plates. I have some additional butyl caulk work to do before it hits rain.
I have not used it beyond testing in the driveway.
2014 F-150
Centerville, OH
Old 07-11-2016, 07:20 PM   #4
2007 22' International CCD
We love ours...be sure to have decent water flow rate and propane pressure. Empty tank and restricted cheap pressure regulators are a pita. Don't ask how I know this. 😀
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
rmkrum is online now   Reply With Quote
Old 07-12-2016, 11:56 AM   #5
2015 30' International
FREDERICK , Maryland
Please keep us posted on its performance.
Doc Foster is offline   Reply With Quote
Old 07-12-2016, 02:20 PM   #6
1978 29' Ambassador
1955 18' Globetrotter
1975 Argosy 22
PIGEON FORGE , Tennessee
You-all did a very professional conversion/ installation(probably better than a Fact. job)
My ignorant question, "Why?" Could you list the pros/cons, reasons, economics, or advantages to educate Forum Followers like myself ?
Thanks Gino Dubay
LEWBAY500 is offline   Reply With Quote
Old 07-12-2016, 08:53 PM   #7
2018 25' International
Sioux Falls , South Dakota
Hi Phil and Kathy,
Great job! Who had the pleasure of the inaugural shower? How long did you bask in the warmth? Did the temperature and pressure of your new heater feel different than your original water heater?
Thanks. The photos are great. Enjoy!
DaytonaDan is offline   Reply With Quote
Old 07-12-2016, 10:39 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Thanks Gino Dubay
I'll add a bit from the professional side.
I have used a Precision Temp in every RV that I have owned since 1999 including the first one that Monaco Coach installed in one of their rigs (40' diesel pusher), then in my 19 CCD Bambi (THAT was a challenging installation!) then on my '96 Beaver Patriot 33' diesel pusher. My Foretravel had an Aqua-Hot hydronic heating system that was also a tankless stare heater.
The Bambi gave me unlimited hot water when on city water with an appropriate drain (sewer connection) and was extremely efficient.....never missing a beat! I would full-time in it for 4-5 months in the summers and did not run down my twin 30# LP tanks.
It also worked well while on the road, but 'Navy' showers were a must then! I would not hesitate to use one again on my next trailer!!! I have installed at least a dozen of them and never had issues!
Old 09-06-2016, 07:43 PM   #9
nickclifford's Avatar
1972 31' Sovereign
felton , California
how hot should they get ?
i installed one in my 1972 Sov, went in very easily. Works like a charm with the pump or city water. Only used it camping twice but now doesn't seem to get that hot, maybe it never really did. How hot should the water be? hot enough where you'd have to mix in some cold too? or barely hot when on full ? It's ok for a "warm" shower but not a steamy hot one? wondering if anyone has any tips for hotter water. The little red valve is fully open. thanks
nickclifford is offline   Reply With Quote
Old 09-06-2016, 08:50 PM   #10
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Anyone have any experience with the Girard tankless water heater? It is half the cost of the precision temp and I am wondering if the precision temp is really worth the extra money.
Greg
Greg1410 is offline   Reply With Quote
Old 09-06-2016, 09:37 PM   #11
lewster's Avatar
The water temp coming from your unit should be at least 120F, which will require mixing in some cold water.
Call Precision Temp and ask for their tech support line. I'm sure they will help diagnose your issue.......1-800-934-9690
Old 09-07-2016, 08:14 AM   #12
1972 31' Sovereign
felton , California
message from their customer service, i'll give it a go.
"Low water temperature is related to water flow or gas pressure or the anti scald adjustment on a shower faucet. If water flow is too low it can’t fully open the gas valve, too high can exceed the ability of the heater to significantly increase incoming water temperature. Try opening two faucets then close one to see if the water temperature increases"
Old 09-07-2016, 05:17 PM   #13
Yup. In real use, I found that low water flow or low gas pressure really makes it act funny. I eliminated a cheap in-line water pressure regulator and make sure my propane tanks are full. No issues since. I suspect water flow was the main issue. Empty tanks (both of them) were no help.
I suspect a low gas pressure situation from a bad regulator could also screw things up. I just had two low tanks. Refill fixed it.
KE4GNK/AE
Old 09-08-2016, 08:54 AM   #14
1972 31' Sovereign
felton , California
[QUOTE=rmkrum;1847469]Yup. In real use, I found that low water flow or low gas pressure really makes it act funny. I eliminated a cheap in-line water pressure regulator and make sure my propane tanks are full. No issues since. I suspect water flow was the main issue. Empty tanks (both of them) were no help.
all good advice, but not great for boondocking if you gotta burn through a lot of water to get a hot shower !
Precision Rivet Removal Tools mistermike Ribs, Skins & Rivets 27 11-09-2013 04:09 PM
New from precision temp lewster Water Heaters, Filters & Pumps 6 12-20-2012 10:40 AM
Precision Temp Installation question ddstech Water Heaters, Filters & Pumps 0 07-10-2012 10:05 PM
Trans Temp & Tach installed bhayden Tow Vehicles 16 08-13-2007 12:25 PM
electric problem precision CANADIAN BOB Member Introductions 2 06-14-2007 01:33 PM
