Old 03-26-2008, 09:26 PM   #1
1958 18' "Footer"
Sebastopol , California
Point of Use Electric Water Heater ?
Has anyone used one in there AS ? I have an 18' Traveler with no shower, it also never had a hot water heater. I've seen 2.5 gal. point of use electric heaters that draw 12.5 amps and plug into 110. I'm wondering if would stand up to RV use. I'd be great to have hot water to do the dishes and wash the face.
Thanks Greg
60's Iron is offline   Reply With Quote
Old 07-07-2008, 01:58 AM   #2
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
I've used an Ariston hot water heater at camp for the last two summers and my brother used it for two years prior to that - so we're on the fifth year. It works fine heating lake water for showers and general clean-up. No complaints - but it is a semi-stationary use. (We take it out of service, load it in the 'Burb and haul it home every autumn). I suspect, with proper mounting to minimize vibration that it will do a yeoman's job of supplying hot water, so long as you have a 30 amp service or budget you AC use judiciously.
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 09-05-2008, 10:35 AM   #3
bookman's Avatar
1972 Argosy 20
youngstown , Ohio
I'm looking into the same thing.. tankless.
bookman is offline   Reply With Quote
Old 09-05-2008, 11:09 AM   #4
cameront120's Avatar
1972 25' Tradewind
You could install an Atwood water heater that runs on both 110 as well as propane with direct spark ignition. It would be more versatile if electric isn't available. You can get one on e-bay for less than $300. Super easy to install, too.
North Vancouver, BC
Old 09-05-2008, 11:10 AM   #5
1972 25' Tradewind
The only tankless water heater rated for RV use is the RV500 by Precisiontemp.
North Vancouver, BC
Old 08-25-2009, 09:12 PM   #6
1985 31' Limited
pensacola , Florida
well i had so much trouble out of mine i went totally electric 12 gallon i bought at lowes for 250dollars which is cheap if you check prices on 10gallon propane i liked to have fell down.can take a shower for about 12minutes and gets hot again in 45minutes,i like how it functions ,didnt buy it for how it looks
bondo is offline   Reply With Quote
Old 08-25-2009, 09:41 PM   #7
1960 24' Tradewind
Riverside , California
Atwood makes an even smaller version, a G4-7 4 gallon LP, not sure of the dimensions but it has to be a bit smaller that the 6
Greg
ZoomZoom is offline   Reply With Quote
To Go All Electric on the Water Heater? Excellaphant 1987 - 1989 Excella 14 07-20-2011 02:20 PM
Gas and Electric water heater and furnace Jim Casavant General Motorhome Topics 4 08-07-2007 07:28 PM
water heater overheats on electric power dikku Water Heaters, Filters & Pumps 0 07-19-2007 06:13 AM
Combination propane electric water heater Pecos Pete Water Heaters, Filters & Pumps 10 03-03-2007 08:40 PM
Point of use water heater 58BUBBLE Water Heaters, Filters & Pumps 3 04-25-2005 05:33 PM
