Old 05-27-2013, 04:22 PM   #1
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Plumbing question
I've taken out all original coper pipes from my 65 Safari. Plan to install new water heater (Atwood DSI gas/elect.) and all pex. Do I need to install low point drain valves?
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 05-27-2013, 04:30 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
yes
Alan
Old 05-27-2013, 04:36 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not know if you do or not. I do know that I have never opened or used the low point drains in the 2 trailers I have. But I think I would put them in anyway if I were redoing all the lines.
Old 05-27-2013, 05:12 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is little need for them as they are often not installed at the low point anyway.
Your best bet is to put a bypass system on the hot water heater drain it in winter and plan to blow the system out before pumping in antifreeze. As I drain the hot water heater I have about 2 ft of small plastic hose in the drain to siphon out the bottom of the heater.
2004 Excursion 4x4
Old 05-27-2013, 05:30 PM   #5
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Tim I think it depends on how you are going to winterize it. I don't but I do make sure all lines have a full flush of antifreeze. Then pour in antifreeze in all traps , and also bypass the wh, then drain out the wh. BTW we installed the Atwood DSI gas /electric... love it. No more pilot!!
goshawks00 is offline   Reply With Quote
Old 05-27-2013, 06:38 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I'll explain a little more about my opinion in post #2, since others seemed to not agree.
If you had a problem with freezing of your old copper lines then you may also have the same problem with the metal connectors in the pex system. Freezing can crack the fittings in the same way as the copper.
Since a low point drain will cost less than $10 to include, why would you not have one? Or, two?
Alan
Old 05-27-2013, 06:53 PM   #7
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
If your low points had anti freeze in them, or for that matter were blown out, why would you need drains?
Old 05-27-2013, 07:01 PM   #8
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I always pumped the system full of antifreeze so never had any freezing problems. I am upgrading to pex to bring it up to date. I didn't think I needed a drain. Good to have others confirm.
Tim
TAC MI 14
Old 05-27-2013, 08:12 PM   #9
Missouri Valley , Iowa
Tim,
I just finished a replumb with PEX on my '89 25'er. I bought the 4 sharkbite valves (@ $15.00 each) planning to install where original drain valves were. When I got to that point of the job I decided not to replace the low point drains. It was going to be a hassle in a small space. I always blow the lines and add a/f anyhow. I even found a drain valve for the city water that I was not aware of! BTW: Sharkbite fittings are pricey but with all the trial and error necessary it was well worth the price.
Dan
Farmer Dan is offline   Reply With Quote
