Old 11-25-2013, 10:45 AM   #15
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
Does your petcock pass the chunks of hard water minerals when you drain the WH?
I find myself using a screwdriver to help break up the chunks as it drains, , ,
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 11-25-2013, 11:05 AM   #16
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
With a valve in the drain it is not going to pass kidney stones as easily. Depending on your use, you would need to remove the valve occasionally and use one of those wand sprayers or just drain it more frequently.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-25-2013, 02:42 PM   #17
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Different water heater configurations have more room then others. Ours has very little so the valve choices are limited. Take a close look to make sure you have room for the valve of your choice.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
