Old 04-03-2015, 12:55 PM   #1
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Pipe Insulation to Help with Water Pump Noise
After filling my water system the 1st time after pulling my AS out of winter storage, I noticed the pump was extra noisy due to some of the pipes vibrating. I winterized my plumbing system by blow out the water with compressed air from my air compressor connected to the water connection.
I decided to purchase one length of 1/2" foam pipe insulation. There seems to be a mass of PEX pipes around the water pump in my Classic 25fb and some of them were touching each other or against drain pipes and the wheel well. I cut short sections of insulation and placed them on the pipes at these contact points. Usually 2" to 4" are enough. This seems to have reduced vibration noise.
Kelvin
Old 04-03-2015, 01:23 PM   #2
1981 31' Excella II
New Market , Alabama
An accumulator would help as well. This would reduce the pressure pulses that cause the pipes to rattle. It is not a bad idea anyway since it would smooth out the water delivery.
Perry
Old 04-05-2015, 02:19 PM   #3
loislane's Avatar
2014 23' International
Saint louis , Missouri
Hi all we have this exact issue - what is an accumulator? We have a 23 ft and the water pump is under the wardrobe but I don't see the other plumbing pipes.
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
loislane is offline   Reply With Quote
Old 04-05-2015, 05:07 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Accumilator is a small tank that allows pump to stay on until it is full and pump doesn't have to come on again until pressure is reduced. I found a small tank at HD a few years ago and it solved the problem with the pump coming on in the middle of the night if you use the toilet. I didn't like the pump cycling while using a small amount of water.
Old 04-05-2015, 05:22 PM   #5
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Name:	ImageUploadedByAirstream Forums1428275992.784888.jpg
Here are a few pictures pre and post install. Only takes 20 minutes.
Name:	ImageUploadedByAirstream Forums1428276086.499354.jpg
ID:	235675Click image for larger version
Name:	ImageUploadedByAirstream Forums1428276117.283266.jpg
ID:	235676Click image for larger version
Name:	ImageUploadedByAirstream Forums1428276155.634256.jpg
SuperTrouper is offline   Reply With Quote
Old 04-05-2015, 05:45 PM   #6
Kevin245's Avatar
Kelvin
Check with Jammer. I believe he tackled this issue a few years ago.
Eleanor Roosevelt
Old 04-06-2015, 01:28 PM   #7
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
They also make a water hammer preventer, that is small and easy to install in-line. You can make one yourself out of cpvc/pvc pipe for less than 5 dollars.
NavyCorpsman is offline   Reply With Quote
Old 04-06-2015, 03:13 PM   #8
KJRitchie's Avatar
2008 25' Classic
I've got a Shurflo accumulator and a Flojet pump, 2008 vintage. All the pipes around the pump rub against each other. My output line from the pump is a flexible hose the is in a loop. I found the water pulse still get through. Maybe newer pumps don't pulse as much as mine. The pump is screwed down tight and has rubber grommets. Its in the most inaccessible location too.
Kelvin
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
pipe/underbelly insulation bonginator 2008 Safari SE 1 09-22-2010 10:32 PM
Water Pump Noise dkekrksk 2002 - 2005 International 11 01-04-2008 08:41 PM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
