02-04-2016, 10:13 PM
Full Time Alumaloafer
1966 24' Tradewind
Livingston
Pinhole leak in Atwood Water Heater
Have a 66 Tradewind that came with a damaged Bowen hot water heater. Since the Bowen was unworkable, I replaced it with a 6 gallon Atwood gas/electric model GC6AA-8. That was about 3 years ago and it has performed flawlessly during full time use, until...
this morning, when I noticed a pinhole leak in the tank. It must have leaked a bit for a while as the black stains indicate. Looks like it ran along the styrofoam insulation seam. This leak is no where near any seams or fittings, and it has not frozen. The tank is flushed periodically and has softened and filtered water. Has anyone else experienced this? How can I prevent the same from happening again? Thanks in advance.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
02-04-2016, 11:54 PM
2005 19' Safari
GLENDALE
, AZ
Just an observation, but it's odd that the primary horizontal rust stain is a straight line. Also, the six vertical rust stains are evenly spaced.
Two questions:
- Is the orientation of this photo the same as the installation in your Airstream; i.e., is your photo rotated 90 degrees?
- Was there something like a metal grate, with the same spacing as the vertical stains, touching the tank?
If the answers to the above are NO, then perhaps there is something (e.g., electric heater) internal to the tank that caused this pattern. If so, this may be a manufacturing or design defect/deficiency; and Atwood might provide a "good faith" replacement or discount, even if the warranty is expired.
Just some thoughts...
02-05-2016, 04:50 AM
1994 30' Excella
Mississauga
, Ontario
Isn't that an aluminum tank? Then the stains are from something else. Could it be from a plumbing leak above draining down onto the tank? Or have you confirmed that it is coming from the tank itself?
Al and Jean
TAC ON-3
02-05-2016, 05:13 AM
1966 24' Tradewind
Livingston
It is an aluminum tank, which had a styrofoam insulator around it prior to removal. The insulator is 2-piece. The stains follow the horizontal seam ( the leak appears to have run from the top to the seam, where it spread before running down within the insulator. I suspect the spacing is due to the styrofoam mold, but may be due to something about the tank.
This is definitely the source of the leak, and the insulator prevented anything else from coming in contact with the tank.
The picture is oriented the way the tank was installed.
Thank you for the input. I have contacted Atwood and will let you know what the response is.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
02-05-2016, 08:06 AM
2013 31' Classic
billings
, Montana
Fix that hole,another will show up ,in a little while my experience.....
02-05-2016, 10:37 AM
Wise Elder
2010 30' Classic
South of the river
Hello Lou
In some parts of the country, the water is acidic and extremely corrosive. I ran into that in north Georgia years ago but there are other places where it is a problem. If you run a pH test on the water you usually use and it's below 7.0 then that's your culprit.
Not much to do now except replace the tank.
Using soft water can make the problem worse in some water chemistries, because the calcium and manganese removed by the water softener have a buffering effect that will raise the pH high enough to prevent corrosion in some cases. Again it depends on the local water chemistry. There are ways that acid water can be treated so if you're having a problem with water that you fill up with at home you could consider getting an acid neutralizer for it. A local soft water dealer would be familiar with the problems in your area and could set you up, or if you are willing to cultivate the expertise yourself you can buy and install one from an online place. I've had good experiences with affordablewater.us.
02-05-2016, 10:39 AM
Wise Elder
2010 30' Classic
South of the river
02-05-2016, 11:10 AM
1977 31' Sovereign
Lynnwood
Although the manual says I don't need it, I use a "sacrificial" magnesium anode in my Atwood.
BTW - In addition to heat and pressure, aluminum corrosion is a function of water chemistry and pH.
Wouldn't it be great if all water had a neutral pH of 7.0?? it doesn't!!
Tom
02-05-2016, 11:33 AM
1996 34' Excella
Elberta
, Alabama
From past experience, both in RV's and our home.....if you have one leak that you can see because of corrosion, there will soon be several more. You might as well bite the bullet and change the water heater...
For whatever it's worth.
Larry
02-05-2016, 11:57 AM
1972 27' Overlander
Woodburn
, Oregon
Tom
Where would I purchase one of these ? I put a Atwood 10 gal in my overlander
02-05-2016, 05:04 PM
1978 25' Tradewind
Metro Phoenix
Exactly. Corrosion theory says that corrosion leaks will appear on a log scale - if you have ten leaks this year, you'll have a hundred leaks next year.
02-05-2016, 07:46 PM
1966 24' Tradewind
Livingston
Thanks for the replies and info. New water heater ordered.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
02-06-2016, 06:16 AM
Gunter
1966 24' Tradewind
Greenville
, Ohio
Have the old tank welded, simple $20 fix.
Gunter
2000 Land Yacht XL 355
02-06-2016, 08:09 AM
1974 Argosy 26
Morrill
, Nebraska
Buy a new tank or complete unit. Chalk it up as the cost of owning an RV. Drain the tank whenever it is not in use.
02-06-2016, 08:39 AM
I always drain mine between uses. Doing so should avoid any problems with water chemistry in addition to any sediment buildup. This would not be possible for full-timers, of course.
My house waterheaters seem to last forever. I guess they're glass-lined?
02-06-2016, 10:23 AM
1977 31' Sovereign
Lynnwood
Get 'em at Camping World or your local RV parts dept. They're pretty common.
Tom
02-07-2016, 07:39 AM
1974 Argosy 26
Morrill
, Nebraska
Perhaps the chemist here can chime in. I don't think the sacrificial anode will be as effective in an aluminum tank as it is in a Suburban water heater which has a steel tank.
The area on the tank that shows the rust appears to be close to the water level of the tank when full.
02-07-2016, 08:28 AM
2005 30' Classic
Burlington
, Ontario
No anode needed with an aluminum tank, and if a pinhole leak is confirmed, IMHO an attempted repair would be a waste of time at this stage - a new water heater is the answer I'm afraid!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
02-07-2016, 09:23 AM
1974 Argosy 20
Kooskia
, Idaho
Atwood has a very good on line manual covering a lot of information on how they work and repairs.
http://manuals.adventurerv.net/Atwoo...er-Service.pdf
On page 26 they talk about leaks and anodes.
