Old 06-19-2012, 09:50 AM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Pilot lights, but shuts off when turned to "on"
I'm camping with my daughter. She has an argosy with a 1 year old Atwood water heater. She can light the pilot light & it stays lit. As soon as she turns it to "on" , the whole thing shuts off. Any ideas?
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-19-2012, 10:12 AM   #2
1974 Argosy 20
Kooskia , Idaho
I would first try to clean the burner tube on the main burner. It is common to get spider webs in it, and then when the main burner is turned on, the gas/air mixture is not ignited but actually blows out the pilot light. Sounds strange, I know, but it has happened to me. Also try to run something up through the tube that goes through the water heater, if spider webs are there, a similar thing can happen.
It sure could be something else, but in the field, that is what I would try first.
Old 06-19-2012, 10:14 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
MAIN BURNER WILL NOT IGNITE
Blocked main burner orifice
--------------------Clean or replace orifice
Main burner flame spreader mis-alignment
--Square flame spreader to end of main burner
Blocked main burner
----------------------------Remove blockage
Improper air adjustment
------------------------Adjust main burner air shutter approximately 1/4 open
Blocked “U” tube
--------------------------------Remove blockage
Gas control out of calibration
------------------Replace gas control
Old 06-19-2012, 11:24 AM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Even though the heater is only a year old,the first thing I would do is change the thermocouple. They go bad at any age. Then I would work from there. Go thru Ganglin's list. GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 06-19-2012, 04:29 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
Yes, we are all blondes....... The gas valve under her trailer was knocked shut! I forgot she even had one, but after going through some suggestions, I called my DH, who has a memory like a trap, and that was the first thing he suggested. Now I can rest assured that my shower is still my own! Thanks all, for all the suggestions---much appreciated!
Becky
1964 Bambi II
1988 Avion 32S
