Old 11-25-2006, 05:21 PM   #1
1971 21' Globetrotter
1964 17' Bambi II
1992 34' Limited
Baldwyn , Mississippi
PEX pipe and the Water Heater
I am replacing the copper in my 71 GT with PEX. The pipe is supposed to be rated at 180 degrees. Do I need to put a 6 or 8" copper stub on the water heater to protect the PEX?
Herb
DoorMan is offline   Reply With Quote
Old 11-25-2006, 05:51 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Water heater thermostats normally do not exceed 140 degF.
You can safely run your PEX right up to the water heater with no problem.
Even if you had a problem, 180 degF is a nominal temperature. You would still be covered.
Tom
Old 11-25-2006, 06:11 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Housing codes even in Mississippi REQUIRE the use of metal (copper or galvanized pipe) within 12 inches of the hot water heater. Now, trailers may be very different and you may be able to place PEX that close to the heat source but for some reason this code still exists. Seems like and easy thing to do and adapt to the heater with copper the PEX. I would check with local codes and see what they require, first.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 11-25-2006, 06:21 PM   #4
1964 17' Bambi II
1992 34' Limited
I can make up the copper pigtails but don't want to do it because of space limitations. It is very tight and I have added several things to the compartment. Thanks for the advice.
Herb
Old 11-25-2006, 06:52 PM   #5
TomW's Avatar
1967 26' Overlander
Originally Posted by clancy_boy
Housing codes ...
Not saying they are different, but Airstreams have to live up to RV Code.
FWIW,
Tom
p.s. And I don't know what the actual words say
Old 11-25-2006, 07:35 PM   #6
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
FWIW,
Tom
True, and I fully agree that you should follow the codes that are relevent to the situation at hand. I am in the overkill mode when I make repairs to anything, I figure the money I save doing it myself that I should do it right, the first time. Somewhere, somehow, somebody decided plastic pipe is not safe near a hot water heater - both input and output lines and so these rules apply in housing codes. I feel it has to do with both temperature and pressure extreems at the same time, say if the relief valve fails. The slim margin of safety allowed by the plastic vs. the copper or galvanized (in my Caravel I used brass fittings) is not enough for me both in cost of parts and time to make it fit.
Good luck, I have heard nothing but good things about PEX and plan a total rebuild of my Caravel using the same.
Old 11-25-2006, 08:09 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I connected my water heater directly with a pair of flair-it plastic elbows to pex. I crank my water heater to max temp most of the time. In about a years time since taking it into service, it has not had any problems with the wter heater and it's connections. I have seen the same installation used in other trailers. When using teh palstic fittings into metal threads, it will be nmecessary to use alittle more teflon sealing tape than usual, to prevent leaks at the fittings.
Just to throw in some real world experience.
Uwe
www.area63productions.com
Old 11-25-2006, 08:54 PM   #8
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
My trailer was setup the same as Uwe's. I got it that way from the PO. No problems here either...
Richard
Old 11-25-2006, 09:28 PM   #9
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Three years here with PEX at the water heater, not a problem. I used brass barbed fittings with compression clamps. Works fine lasts a long time.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 11-25-2006, 09:44 PM   #10
Alumicult in Oregon
edgeman's Avatar
1981 27' Excella II
Seaside , Oregon
Thumbs up Pex to the hot water heater
International Residential Code (IRC) allows pex to be hooked directly to the hot water heater. It is rated for hot water and is allowed by IRC that has been adopted by most states since 2003.
edgeman is offline   Reply With Quote
Old 11-26-2006, 09:33 AM   #11
1964 17' Bambi II
1992 34' Limited
Thanks everyone for the help.
_________________________
Herb
