Old 11-01-2003, 09:15 PM   #1
Deluxe21's Avatar
Images: 24
Parts for 58 water heater
Well I have been playing with my water heater and it doesn't seem to want to work. The pilot light will stay lit but the main flame will never come on. I checked it in the dark and when switching from pilot to On the flame inside the tube stays the same. I wanted to replace the main control unit but the local RV shop said that the new controlers have the thermastat built into them. Looking at those I realized they would not work in my system. The thermastat is seperate form the main valve and the thermocoupler is two wires not a tube like the new heaters use. Are there parts available for these older heaters or is it time to replace it? Any help would be great.
Steve
Deluxe21 is offline   Reply With Quote
Old 11-03-2003, 06:42 PM   #2
Deluxe21's Avatar
Images: 24
Fixed
Well I was able to remove the thermostat and install an attwood replacement unit and it works great. The only other thing I had to upgrade to the newer type was the thermocoupler.
Steve
Old 12-23-2003, 08:14 AM   #3
Same Problem
We have about the same problem with our OEM 63 WH. Pilot lights, but can't get beyond that. Can you tell me exactly what you bought and from where to make yours work? I'm clueless with this old water heater and don't want to replace it if I don't have to. Thanks!!
Alan and Mardel
Alan and Mardel is offline   Reply With Quote
Old 12-23-2003, 01:35 PM   #4
Images: 59
Same problem
I have a '59 that I haven't torn apart yet, but expect to need parts. Help with more info?
Old 12-23-2003, 06:43 PM   #5
Deluxe21's Avatar
Images: 24
I'll take a pic of the finished product and post it as soon as I can. As far as I know any RV shop should carry the replacement. I got mine in Miami at K&K.
Good Luck
Steve
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Atwood Water Heater Parts? ViewRVs Water Heaters, Filters & Pumps 1 04-08-2003 08:13 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
