Old 06-13-2008, 12:22 PM   #1
HansenClan's Avatar
1965 26' Overlander
Encinitas , California
Images: 22
Par/Jabsco Water Pump Belt?
Anyone know where to find replacement water pump belts for my Par/Jabsco water pump from my 1965 Overlander?
The pump still works great, but the belt is aging and I want a replacement or two on hand just in case..
Thanks fellow Forum'ers!
HansenClan is offline   Reply With Quote
Old 06-13-2008, 12:56 PM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I just purchased a rebuild kit for my Jabsco-Par pump from Ess-Kay yards.
Try this link:
Ess-Kay Yards Ship's Store
When I took my pump apart to build it there was some cracked areas - I had to send back the pump and order a new Shurflo Whisper King pump.
Anyway I had good luck and quick shipping with the company noted in the link above.
crispyboy is offline   Reply With Quote
Old 06-13-2008, 01:27 PM   #3
crispyboy's Avatar
1994 30' Excella
Here is a better link:
Jabsco Par Parts & Accessories at NAUTICAL GIFTS
Old 06-13-2008, 03:47 PM   #4
HansenClan's Avatar
1965 26' Overlander
Images: 22
Thanks!
Originally Posted by crispyboy View Post
I'll check it out!
Old 06-13-2008, 05:19 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
A common problem with the cog belt is over-tightening. You should be able to depress the belt @ 1/4" halfway between the pulleys.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-13-2008, 06:26 PM   #6
HansenClan's Avatar
1965 26' Overlander
Images: 22
Belt tension
Good information, thanks!
Old 06-14-2008, 03:47 AM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Speak up - I can't hear you over the water pump
FWIW, my original plan was rebuild my original PAR water pump. But since it was low on the priority list compared to what else my Overlander needed, there was time to research the issue.
Everyone agreed that the PAR pump does a fine job pumping water, "but they're kind of loud". Then one poster (I think it was Overlander64) mentioned that people noticed his Argosy at a rally, "I woke up everytime that guy went to the bathroom!"
I ended up get a FloJet VSD pump.
Tom
Old 06-15-2008, 02:06 PM   #8
Excella CM's Avatar
Venice , California
Once again. With Par style pumps you should use an ACCUMULATOR TANK to cut down wear and tear as well as noise.
Old 06-15-2008, 04:42 PM   #9
There are rebuild kits available, that really overhauls the entire pump.
But if you do that, it will probably only last another 40 years.
Old 06-24-2008, 08:43 AM   #10
clearwater , Florida
Par parts
Depco pump has all parts for Par pumps. They even have breakdowns of the pump models on their website Depco Pump Company, use the search engine or call their marine sales department
mariab is offline   Reply With Quote
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
new water pump - Jabsco sensor max 14 adonh Water Heaters, Filters & Pumps 2 11-15-2007 02:54 PM
Rebuild PAR 6800J (Jabsco 36800) or Replace with New Pump trevisgardne Water Heaters, Filters & Pumps 3 05-02-2007 09:20 AM
Jabsco strainer Par Pumpgard crispyboy Water Heaters, Filters & Pumps 7 04-30-2007 01:43 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
