Panel to replace hole left by removal of water tank?
Hi, I have removed the old water tank from my '68 Overlander 26', and am planning to install a tankless heater in its place (brand not decided). However, currently, I am left with a hole in the side of the trailer where the tank came out and from the removal of all the old propane tank fittings that were accessed from the exterior. The collection of small panels and aluminum strips that I removed in order to remove the old tank were flimsy and did not survive, apart from a small vented panel which I have kept. The doors that come with the new tankless water heaters are not big enough to fill the space, and are painted anyway, so are of no use. Is it possible to buy a vented panel which I can cut to fit this space? As I see it, the only other option is to buy the bottom-vented RV-500, and just fit a plane panel which I will need to cut to fit? Any advice will be much appreciated, thanks.
