Old 01-05-2011, 06:15 PM   #1
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
Panel indicator light for water pump and Water heater
Hello all, My new-to-me, and barely used '04 Safari LS has an indicator light on the panel above the stove for the water pump. The pump works fine, but the light never goes on. Is it suppose to?
Same issue in the bath room- indicator light for the water heater never goes on, but the WH works just dandy.
Suggestions?
Don
DJW is offline   Reply With Quote
Old 01-05-2011, 07:27 PM   #2
SteveH's Avatar
Common Sense , Texas
Don't know about the water pump light....might be simply burt out, but the water heater light is sort of an alarm light. It only lights when there is a problem and the heater won't relight correctly.
To test that, turn off the gas and turn on the water heater. The red light should come on then.
Regards,
Steve
Old 01-05-2011, 07:28 PM   #3
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
Don
The light is working correctly. It will flicker (once) when the hot water tank is trying to light. It will stay light if the tank doesn't light (usually when there is no propane in the line)
All the best
Paul
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 01-05-2011, 08:01 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Originally Posted by bolerama View Post
Don
All the best
Paul
That's the way the one works on our '83. When I turn the water heater switch on, the switch glows red until the water heater lights, then it goes out.
Check the bulb on the water pump light.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Advice on 454 radiator cooling fan porourke Mechanics Corner - Engines, Transmission & More... 18 02-10-2011 11:12 AM
Fresh water intake for '58 Caravanner Ron Banks Fresh Water Systems 8 01-04-2011 11:19 AM
2006 Airstream Safari 22' 75th Anniv Special 500 miles! eBay Watch Airstreams on eBay 1 01-04-2011 08:08 AM
Any common/known problems/deficiencies on a 2004 International 28'? FullTimin2HI Full-Timing 17 01-01-2011 05:06 AM
