Old 02-27-2008, 07:39 AM   #1
Paint for water heater door
Just replaces the original water heater with an atwood. It has a white door and I want to paint it gray. Do I need to wuse high temp paint or does it matter. Any suggestions?
nbka1bm is offline   Reply With Quote
Old 02-27-2008, 08:27 AM   #2
RichardT's Avatar
The whole door doesnt get hot, just the small area above the exaust. I think you do not need high temp paint. But it couldnt hurt.
Personally I would keep my eye open on Ebay and buy an Aluminum or stainless door to replace the white one.
RichardT
RichardT is offline   Reply With Quote
Old 02-27-2008, 09:36 AM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I made the same change in water heater not long ago. I, too, didn't like the white door so I took paint remover to it to get it ready for a new coat of paint. The "finish" underneath that was not affected by the paint remover was a grey that fairly well matches aluminum. I managed to do just the outside, so the inside with instructions is untouched. It has been this way for 8 to 10 months now and I may or may not paint it. Try it, you have nothing to lose.
Sam
samb is offline   Reply With Quote
Old 02-27-2008, 09:55 AM   #4
Lee Pace's Avatar
We went to Auto Zone and got the chrome paint and it matched our Tradewind perfectly.
Good Luck,
Gloria Pace
Lee Pace is offline   Reply With Quote
Old 02-27-2008, 10:51 AM   #5
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I just used a silver paint from Ace Hardware. I say it is temporary as I want to adapt the original (can't recall the make) door. You will notice that I did reinstall the original door face (frame). Since this installation I have gotten used to the 'painted door' and though I want to use the orginal the priorty level is slipping. The Atwood is a great WH though.
Name:	Airstream - New water heater install 6-07 035.jpg
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-27-2008, 11:55 AM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I used a high temp silver engine spray paint for the Tradewind. Looks pretty good!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-27-2008, 12:00 PM   #7
krikles's Avatar
1965 17' Caravel
west hills , California
I had mine nickel plated (or chrome plated - can't remember which) and it looks awesome. No worry of peeling paint, etc.
Thousands of tired, nerve-shaken, over-civilized people are beginning to find out that going to the mountain is going home; that wildness is necessity; that mountain parks and reservations are useful not only as fountains of timber and irrigating rivers, but as fountains of life.
-John Muir
krikles is offline   Reply With Quote
Old 02-27-2008, 12:18 PM   #8
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I painted the new door for my Argosy water heater with Keylon about 3 years ago and it still looks good as new. I got the LP/Electric model and have never used it on gas, but don't know if that makes a difference.
juel is offline   Reply With Quote
Old 02-27-2008, 03:13 PM   #9
ronpovey's Avatar
Vernon , British Columbia
Took the water heater door and outside furnace cover to an autobody shop and had them painted a nice off silver color. They had started to oxidize, the shop cleaned them up and did a nice job of painting.
ronpovey is offline   Reply With Quote
Old 03-02-2008, 08:30 PM   #10
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Central , Illinois
water heater cover
I took a little different approach. After taking out the old Bowen and getting a new Atwood, I thought it would be something of a challenge to reuse the old stainless steel door. Since I had purchased a piece of 2024 T3 aluminum to do some patching and repairs, I choose to use some automotive epoxy and glue a piece on the white Atwood door. The edges have 3 coats of a cold galvanized paint to cover the 1/4" return on the door.
I still have the old stainless door if anyone wants it for the cost of shipping. The challenges I saw in retrofitting it were:
The new Atwood door has a 90 degree return on the edges, the old one has an angled face and no return.
The new Atwood has two pin hinges, the old one has a piano hinge.
The new Atwood has one camlock in the middle of the door, the old one has two camlocks at the upper corners of the door.
Maybe a better mechanic than I could make quick work of it, if you want to give it a try, please let me know.
Name:	new wh cover.jpg
maccamper is offline   Reply With Quote
Old 03-02-2008, 09:48 PM   #11
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Roger Williams AS in TX has a SS replacement. I put one on mine and she looks nice. Give them a call and talk to David.
Michelle TAC MT-0
Sarah, Snowball
Old 03-03-2008, 05:31 AM   #12
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Does Roger Williams have a SS replacement for the Suburban too? I really like the idea of SS instead of the faded silver painted version. I inquired baout having it chromed and was told the metal wouldn't hold up to it.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-03-2008, 08:25 AM   #13
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Stainless replacement
We replaced our water heater, furnace and range vent with stainless replacement covers from Roger Williams. I believe they have a source in their area that makes them. I had to bend some edges on the water heater to make it fit well but they sure look nice. Why airstream didn't put on stainless or aluminum in the first place kind of annoys me. I know it is cost to manufacture but another $300 would not have disuaded me from buying the AS.
altamont is offline   Reply With Quote
Old 03-03-2008, 11:06 PM   #14
Keymar , Maryland
Give them a call and find out. I do not know.
Michelle TAC MT-0
Sarah, Snowball
Vintage '70s Shower Door and Water Heater Door -- Freebie maccamper General Repair Forum 6 05-15-2009 10:18 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Old Door - New Water Heater Ganglin Water Heaters, Filters & Pumps 14 09-04-2007 11:33 PM
Where can I get a stainless water heater door? Silver Threads Water Heaters, Filters & Pumps 4 06-23-2007 06:51 AM
