Old 03-04-2008, 04:01 AM   #15
Baltimore , Maryland
Here is what I did....
This was done by using SamB's old Bowen cover. I wrapped the door after painting it silver. There are detailed photos on my blog.
Old 06-17-2008, 08:19 PM   #16
JimGolden's Avatar
1977 31' Excella 500
I'm in a similar boat. I just put a new 6 gallon gas/electric Atwood in my rig. I got chrome paint at AutoZone. It looked really nice, but using LP it softened and lines formed in it. I had done five coats of chrome and three coats of clear.
Well I spent two hours tonight sanding it and I got most of it off. I picked up two cans of 1200 degree ceramic aluminum colored paint. That should fix it.
My old door is stainless and it looks fine. But, the new Atwood's have a larger grill than the old ones. It's not by much, but enough that it won't work. If I don't use the grill, my old door will mount right up. But, the new grill won't work with the old door. As well, the old one had the grill mounted to the exhaust and the door just had a hole in it; the new one has the grill mount to the door and it sets out a bit, so that furnace exhaust projects slightly out into the hole in the door. I can't see how to make the old one work.
Does the Roger Williams one fit the new water heaters with the larger hole and the grill that attaches to the door itself?
- Jim
JimGolden is offline   Reply With Quote
Old 06-17-2008, 08:50 PM   #17
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Originally Posted by thecatsandi View Post
Roger Williams AS in TX has a SS replacement. I put one on mine and she looks nice. Give them a call and talk to David.
Thecatsandi
Can you post a picture of the stanless steel water heater cover you purchased from Roger Williams and provide a ballpark cost?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 06-17-2008, 08:56 PM   #18
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Jim--I'm far from expert in these matters (as I've screwed it up once!), but I re-used my older Atwood shiny door by replacing the heat duct from the new Atwood with the old one. With a little attention to alignment, it will work. Pay close attention where the screws go (ask me how I know!). My old duct was a little rusty, but not enough to bother me. I had to stack some washers as a spacer to take up room between the old duct and the new heater (see second photo). The screws line up well to secure it in the same two spots as the new one uses (see third photo). DON'T put a screw in the bottom right corner where the old one has a spot. It's too easy to hit the tank (as I found out!). The end result (last photo).
ID:	62517   Click image for larger version
ID:	62521   Click image for larger version
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-17-2008, 09:05 PM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Roger Williams...the Best
These are great replacements!!!
Name:	STAINLESS UP-GRADES 013.jpg
ID:	62525   Click image for larger version
Name:	STAINLESS UP-GRADES 003.jpg
Name:	STAINLESS UP-GRADES 006.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-23-2008, 04:00 PM   #20
2dabeach's Avatar
R. Cross
Thanks for the great pictures of the covers available from Roger Williams Airstream. I've seen posts regarding their covers but never saw a post with pictures. After seeing your pictures I ordered the covers for the water heater and the furnace. I wish Airstream would have spent a few dollars more to upgrade the covers at the factory.
Old 06-23-2008, 04:10 PM   #21
Thumbs up Your Very Welcome
Originally Posted by 2dabeach View Post
R. Cross
WE ALL DO!!
PFC
"Tahawus"
RLC
John Prine
Vintage '70s Shower Door and Water Heater Door -- Freebie maccamper General Repair Forum 6 05-15-2009 09:18 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Old Door - New Water Heater Ganglin Water Heaters, Filters & Pumps 14 09-04-2007 10:33 PM
Where can I get a stainless water heater door? Silver Threads Water Heaters, Filters & Pumps 4 06-23-2007 05:51 AM
