12-30-2016, 10:18 AM
2015 16' Sport
Evanston
Opportunity to upgrade after a bonehead move
So - Mia culpa - I neglected to drain the hot water tank on our 2015 Bambi 16 sport before a deep freeze and it burst. I lucky had gotten through winterizing the rest, but missed that. SO. I am interested in your suggestions for an upgrade instead of replacing with the OE water heater, or is the OE Atwood still a good choice?
thanks in advance for your input.
12-30-2016, 10:34 AM
1993 34' Excella
Estancia
, New Mexico
Tankless on demand heater?
12-30-2016, 10:57 AM
2007 22' International CCD
Corona
I replaced the Atwood with a PrecisionTemp tankless. Easy swap.
Wife loves long hot showers, and this delivers.
12-30-2016, 01:27 PM
1966 22' Safari
Hilltop Lakes
I also have a Precision Temp 500. I'm glad I installed it every time I take a shower in the trailer, and also every time I do several months of camping before I have to fill a propane bottle.
12-31-2016, 08:37 AM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
I put an RV500 in the 2012 25FB and just loved it! You do have to open the wall a bit to fit. The RV500 was great. I put an RV550 in our 2015 Bunk before we took our first trip. The RV550 is a big disappointment. You have to constantly adjust the external temp control depending on outside temps. We also could not get it to adjust to lower temps when showering until I called Precision Temp and complained. They said to turn the sink hot water on to a pencil size stream which allows us to regulate the temps pretty good. I was offered to test a new pre-production unit that is supposed to be more like the old RV500 but decided the sink on trick worked well enough. I would not trailer without an instant on constant hot water system. Check with Precision Temp and make sure you get the latest model not an RV550. You will love it.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
12-31-2016, 10:32 AM
Vintage Kin
Fort Worth
Aren't those propane only?
12-31-2016, 10:45 AM
2019 27' Flying Cloud
Kansas City
, Missouri
Unless you routinely camp with full hookups (including sewer) I think you would be best served by simple replacement.
Your AS has the smallest capacity waste holding tanks of any model. So unless you have the ability to drain more, and easily, there would be no advantage to limitless hot water.
Piggy Bank
12-31-2016, 11:44 AM
2013 31' Classic
billings
, Montana
Nothing wrong with the original...
01-01-2017, 06:53 PM
2015 30' FB FC Bunk
Golden
The RV500 series is gas only but it is very efficient. It also makes winterizing a breeze as you don't have to fool with draining the tank every time!! I just pump antifreeze thru and since I do this 3-4 times a year it makes a big difference for me. My wife and I bought the Airstream as an extension to our home life style. We don't boondock except for an occasional overnight stay at Walmart if an RV Park is not available. We both wake up and shower one after the other enjoying a nice hot and often long shower. When our 16 year old is along he does the same. All Airstreams should come this way especially the Bunk model. But then it only came with one single towel rack in the shower. Go figure.
01-01-2017, 10:10 PM
1999 34' Excella
Hillsboro
Run original with electric and boost with propane for high consumption and it works great. Shut off the propane switch for normal use.
Peace and Blessings..
Channing
WBCCI# 30676
01-02-2017, 11:56 AM
Vintage Kin
Fort Worth
The standard formula for fifty years.
01-02-2017, 12:26 PM
Southwestern
, Ohio
Was your original equipment Attwood dual mode - gas or electric - or just gas? Easiest to replace with original equipment since it won't require mechanical modifications, but I would upgrade to gas-electric model if the original was gas only.
01-04-2017, 03:15 PM
1964 26' Overlander
Milton
, ON
I did the same thing this winter! I think I got interrupted part way through winterizing and didn't realize until we'd had a few days well below freezing that I had missed doing the water heater. I drained it on a mild day and haven't had a chance to check for damage, but I suspect it's toast.
01-04-2017, 04:46 PM
2000 19' Bambi
mt. Prospect
The std hot water tank holds six gallons of water. The tankless Precision only holds a pint or so. That's six gallons or water storage you are giving up, and you don't have that much to start with. I would replace with the same you have.
No WD, but a great DW!
01-04-2017, 05:34 PM
1986 31' Sovereign
Miami
You know, not long ago I made the "your losing six gallons of storage" argument and it was pointed out to me that I was mistaken. Sure, there is six gallons of water in the hot water tank, but you can't use it (well, I guess you could drain it into a bucket) because the water pump is upstream.
If you think about it...
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
