Old 10-20-2014, 09:08 AM   #1
Brooklyn , New York
On Demand Electric Water Heater
I am trying to figure this out, and thought I would turn to you guys for some help. I'm 1/2 way through hopefully a complete restoration, and I'm picking out appliances. The tradewind (66) will be used mainly as an additional quest house on my land. My question with this being the primary purpose of the airstream (not boondocking) is can I have an ondemand say 220v 9kw electric water heater which will give my around 3gpm, and use a step-up converter like this to get me from 110 to 220v Amazon.com: Goldsource STU-N Series 10000W Heavy-duty AC 110/220V Step Up / Down Voltage Transformer / Converter with US Standard, Universal, German/French Schuko AC Outlets & DC 5V USB Port - 10,000 Watt: Automotive
I just want to have one line running into the airstream and have a separate breaker in the airstream.
Does this make sense? Would it work? And thoughts or advice much appreciated. Thanks.
Trady66 is offline   Reply With Quote
Old 10-20-2014, 10:22 AM   #2
1974 Argosy 20
Kooskia , Idaho
Watts = volts x amps. Or amps = watts/ volts.
A 10,000 watt demand heater at 240 volts takes close to 42 amps. I am not clear why you want a transformer unless you are thinking you can run this heater on 120 volts transformed up to 240 volts. Is that what you are thinking?
If so, at 120 volts the amp load would be twice that at 240 volts, or about 84 amps.
The original airstream cord is good for 30 amps max at 120 volts.
So, it is unclear what you want and why, but the original cord will not work.
Old 10-20-2014, 10:27 AM   #3
Dayton , Washington
If you want an on demand water heater, buy a propane one....
Streampunk is offline   Reply With Quote
Old 10-20-2014, 10:27 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
If it were me, I would not make that choice.
I would suggest using a traditional rv type water heater, either propane/on demand or a combination propane/electric 6 gallon.
(just my $0.02s)
Alan
Old 10-20-2014, 01:29 PM   #5
Brooklyn , New York
Thanks for the replies. I do not want to go with propane, as the whole airstream for the most part will be next to my house, so I can use my electric supply. I want to use a tankless electric heater to heat the shower and faucets. A tankless heater like this...
PowerStar 7.2 kw 240 Volt Point-of-Use Tankless Electric Water Heater-AE7.2 at The Home Depot
It is 30 amps, 7.2kw, 240v.
I am putting in completely new electrics including shore-line.
What I am wanting to do is use a step-up transformer from 120v to 240v.
Is there any reason this would not work?
Old 10-20-2014, 01:52 PM   #6
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Why not wire the camper for 50 amp service and use that as a source of 240 volts? I'm no electrician, but you need to talk to one.
Power doesn't come from nowhere. That's what people above were trying to tell you. It's not enough to 'step up' the 120 volts to 240 volts; such a move would at least double the amperage requirements on the 120 volt line. Similar to how running a 3 amp appliance at 120 volts requires at least 30 amps at 12 volts.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-20-2014, 04:33 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
even if you had 50 amp RV service in the trailer it would still only be about half enough power to run that water heater. You need to pick out a water heater that draws substantially less power. If that heater draws its rated capacity it would have to be on a 40 or 50 amp 220 circuit in a house. About like a electric range. The idea of rewiring the trailer to 50 amp RV service is one way to get 220 for something like a on-demand water heater to a trailer. But you still need a much smaller capacity heater. And if there is no propane the refrigerator, the stove, and any space heater will all draw electric power also. Plus hair dryers, toasters, etc.
Old 10-21-2014, 01:53 PM   #8
1967 26' Overlander
Montgomery , Alabama
If you want a shower forget the tankless electric. A 12 Kw Tankless electric water heater will only deliver a 45 Degree rise at 2 gallons a minute. Summer time in the south it would be fine. In coming water at 70 degrees summer time but winter at 45 incoming temp= 90 degrees luke warm
I sell plumbing for a living. Electricity can not produce enough heat to do a shower economically.
l.flegel is offline   Reply With Quote
Old 10-22-2014, 10:02 AM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
X2. Listen to what others are telling you. Remember that new solutions have new problems. Like Alan said, go with a 6 gallon combo (electric/propane) water heater. It will work just fine.
Dan
Report on Marey On Demand Tankless Hot Water Heater Collapso LP Gas, Piping, Tanks & Regulators 5 12-08-2012 05:44 PM
Atwood on-demand water heater svanpelt Plumbing - Systems & Fixtures 1 11-28-2012 10:34 PM
On Demand Water Heater? codybear Water Heaters, Filters & Pumps 4 06-04-2011 10:27 AM
Small Electric on-demand water heater and a 20A plug Globie64 Electrical - Systems, Generators, Batteries & Solar 5 04-14-2011 07:49 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
