Old 10-23-2010, 12:23 PM   #1
1971 29' Ambassador
South Weber , Utah
old water heater 71 airstream available to a good home
Replaced my water heater recently. Old pilot would not stay lit. Have most of the old unit available for parts or or restoration (missing springclips for door and exaust diffuser) . Believe it is the original. Tank did not leak last time we used it. Let mem know if anyone interested otherwise to the dump shortly.
fisherjdou is offline   Reply With Quote
Old 11-11-2010, 10:21 AM   #2
Q Cycle's Avatar
1961 24' Tradewind
Albuquerque , New Mexico
Send a message via Skype™ to Q Cycle
Old water heater
Hi,
Do you still have it? Is it an original Bowen by any chance or were these already obsolete by 1971?
Bill
1964 Tradewind. First AS.
Q Cycle is offline   Reply With Quote
Old 11-13-2010, 09:15 AM   #3
1971 29' Ambassador
South Weber , Utah
Yep, still have it
Bowen G10B? 9.9 gal.
Old 11-16-2010, 09:16 AM   #4
Q Cycle's Avatar
1961 24' Tradewind
Old water heater
Hi,
Thanks for the reply. I am most interested in the outside cover. Is it original and intact? Is it the embossed vertical lined aluminum "backing plate" with kind of a folded over "corrugated" cover?
Bill
Old 11-19-2010, 04:32 AM   #5
1973 29' Ambassador
ozona , Texas
Hello ,
I am new to a/s and the forum. Just got a 73 international 29' and everything leaks ,including the water heater. It is the Bowen G10B and the burner and controls work but the tank leaks.I have replaced most freeze damaged copper tubing with PEX and crimp conections but need a hot water
heater. I am in Ozona, (West Texas) and could use a hot shower.
Charlie
charlierm is offline   Reply With Quote
Old 11-19-2010, 04:22 PM   #6
1971 29' Ambassador
South Weber , Utah
It is all original...I think. no corrigated material that I can see. Exterior is smooth sheetmetel. Either aluminum or galvanized as it doesn't look rusty. Tank did not leak last time we used it before the pilot quit working. Was a pretty easy job to swapout to new model except the pain of removing the trim belt and having to modify to re-use the old stainless door.
Airstream - a good "starter home" for a young couple? AtomicKiwi Full-Timing 22 07-28-2010 12:51 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Airstream help? - Water heater tigerray123 Member Introductions 0 07-01-2007 11:40 PM
Almost free to a good home Buttercup Refrigerators 4 03-27-2006 07:33 PM
