Old Atwood will not stay lit
The thermocouple is electrical in nature. It generates a few millivolts and a little current to power a solenoid coil that holds a magnet to keep the gas on when you turn the knob to ‘run’.
What you described sounds like the thermocouple is not making good enough contact with the gas valve contacts.
It should not be super hard to screw it in, and it should bottom out easily. If it’s not making solid connections, what you described will happen for sure. Try to get it properly screwed together is all I can suggest. If it’s cross-threaded it will not get a good connection before it becomes impossible to turn.
