Old 02-10-2014, 07:19 PM   #1
1999 28' Excella
New Orleans , Louisiana
Oh no..an icicle under my Airstream
Found a small icicle under the water connection compartment. Opened up the hot water heater thingy and the little panel was wet. Had noticed the hot water tank was a little noisier and the water pump seems to run more.
What's up guys?
badkat is offline   Reply With Quote
Old 02-10-2014, 07:43 PM   #2
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Pump is running more because there's a leak letting the pressure off. Leak could be a weak pipe that had been frozen, getting ready to do the big bang for you. Noise could lead you to water burning in the burner compartment in the water heater, if it's gas.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 02-10-2014, 08:22 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is the pressure relief valve on the water heater dripping water? That could be the source of your icicle.
Old 02-10-2014, 09:14 PM   #4
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Not exactly sure where the ice is or where the "water connection compartment" is on your trailer. Because your pump is running more often, you must have a leak in the pressurized line or system somewhere.
Ditto on the pressure relief valve on the hot water tank as being something you want to look at first. It should be easy to check out and quickly confirm or eliminate it as the source. A burst pipe will usually be split and leak big time. It sounds like you don't have a gusher, just a very slow leak, correct?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-11-2014, 06:00 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Pressure relief valve should stay closed unless: (1) you opened it while winterizing to make the water heater drain faster, and forgot to close it again afterwards; or (2) the water heater overheated and made steam. Also, since the pressure relief valve is at the top of the tank, it's unlikely to be the cause of your drip. On the other hand, the water heater drain plug might not have a good seal. That would account for both the drip and the water pressure loss.
On edit— If your water heater is overheating and making steam, that could certainly be the cause of the extra noise, as the water inside boils like a teakettle, as well as the source of the mysterious moisture and water pressure loss.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-11-2014, 08:22 AM   #6
1999 28' Excella
We have not winterized. We are full-timing. So we are losing water pressure. We just had a water regulator replaced because our trailer had low pressure. Pressure go a lot better. The little black panel with wires is wet but guess could be condensation. Have an mobile RV guy looking at it in a couple of days. Best we could do..everything at Buda TX RV shops are booked. We will be within a mile of one that handles AS service though.
If the water heater is overheating..can that be adjusted or does it have to be replaced?
We do not have a gusher just a constant drip not stream.
Old 02-11-2014, 08:26 AM   #7
Should just be a matter of replacing a thermostat or thermocouple.
WBCCI #1105
TAC LA-4
Old 02-11-2014, 08:29 AM   #8
1999 28' Excella
The water heater is gas and electric. We mostly use electric.
Checked under cabinet where heater is and there is no water there.
Old 02-11-2014, 08:30 AM   #9
Thermostat, then. Thermocouple is normally near the gas flame.
WBCCI #1105
TAC LA-4
Old 02-12-2014, 09:11 PM   #10
1999 28' Excella
Stayed tuned..will let you know what the mobile RV repair guy says tomorrow. Best we can do in Austin, TX. Service depts are booked.
Old 02-12-2014, 09:48 PM   #11
1988 32' Excella
Robbinsville , New Jersey
If you have had water in the system for a long time it is possible for the air pocket in the water heater to be absorbed and cause the relief valve to leek do to the lack of air pocket not giving the water anyplace to expand.
If this is the problem you would need to shutoff the water and drain some water out of the water heater to allow air in for the expansion pocket.
Some were complaining about this being a common problem with some of the newer gas/electric water heaters
Old 02-13-2014, 12:16 AM   #12
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
If you use propane a lot, it burns dirty and creates condensation. Your water heater needs to be cleaned and have the soot blown out if there's any sooting around the vents or on the side of the Airstream. Condensation from propane can be a problem though I'd guess the prior posters have it right with the relief valve or drain valve.
Paula
Old 02-14-2014, 07:45 AM   #13
1999 28' Excella
Leak is fixed!
Well the leak is indeed fixed after about 20 minutes at most.
I'll start at the beginning..2 weeks ago we were at a shop for little list of repairs. They noticed our water pressure was low and said the water regulator needed to be changed. They ordered the part so we went back again to have it installed. That bill was about $70.
We left New Orleans area then noticed the leaking.
Now of course we are in the Austin area. Shops are booked so they gave me a mobile guy's #. $100 trip charge and $99 hr. oh well!
He spent about 20 minutes total finding the problem and replacing the washer behind the regulator that was kinda torn up.
No more leaking.
Old 02-14-2014, 03:10 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
That's an expensive washer!
1962 Airstream Overlander 26 - California schweizerfam Airstream Classifieds 0 02-03-2014 10:17 AM
1963 Airstream Safari 22 - Arizona 1920jr Airstream Classifieds 0 01-30-2014 12:01 PM
