05-07-2012, 08:59 AM
2004 25' Safari
East Northport
, New York
Noisy water pump
We bought our Airstream a little over a month ago. We went camping for the first time and noticed that the water pump is very loud. I've read about other people having water pumps that make a lot of noise too. We were the only people camping where we we were, I was surprised how loud it was outside. What is the best way to take care of this? It would be annoying to anyone camping near us. I've read some people use foam, any help would be appreciated.
05-07-2012, 09:11 AM
Oswego
If you'll use the search function in the blue bar above and search on "noisy water pump" IN THE GOOGLE search field, you'll find many posts about how to reduce the noise. Lots there!
-Rich-
05-07-2012, 09:15 AM
2002 25' Safari
Dewey
Air in the lines will cause the pump to "hammer". Always be sure to bleed the air from all the lines when you get setup.
Richard
05-07-2012, 09:23 AM
1978 31' Excella 500
Venice
You can add an accumulator tank to the system. Cheap and effective.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
05-07-2012, 09:41 AM
Master of Universe
2008 25' Safari FB SE
Grand Junction
Mount the pump on a rubber mat or use rubber washers under the screws that hold it down. I did the latter and it helped a little, but mostly we just ignore it.
Gene
05-07-2012, 09:52 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I re-mounted ours on these...helped some, but the fact that Fibber's closet is stuffed probably helped more.
POI....on edit.....after I did my sooper up-grade, it werked so well I didn't hear the the pump running and upon my early morning visit to the head was jolted awake by a flooded floor.
Be careful what you wish for.
"You don't know where you've been until you leave, enjoy life" RLC
05-07-2012, 09:53 AM
2006 16' International CCD
Niagara Falls
, New York
Add foam pipe insulation to the water lines everywhere the pipes are against the floor or wherever the pipes run thru walls/shelves. Basically anywhere you have access to the water lines, insulate them. Foam pipe insulation can be bought at any home improvement store for just a few $. That hammering sound drove me crazy too.
05-07-2012, 01:54 PM
2006 19' Safari SE
Tucson
Some excessive noise can be caused by the vibration of pipes right at the pump itself...if you can reduce the vibration there by securing or padding the lines better, it should help.
Richard is also right, that if you have air in the lines it can cause a very annoying loud hammering sound...we use the shower to bleed the air out of the lines since that's the highest point in the system...just let the shower run a bit and see if that helps.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
05-07-2012, 03:12 PM
2004 25' Safari
East Northport
, New York
Thanks everybody. Some great ideas.
10-21-2016, 10:49 AM
2014 27' Flying Cloud
Groveland
Loud Water pump
I used a "fun noodle" one of those tube shaped floating devices and cut it to size, wrapped it around the plastic water pipes where they came in contact with the frame.
Cost about $2 and my problem was fixed.
10-21-2016, 12:57 PM
2014 25' Flying Cloud
Cuddebackville
, New York
MY pump is mounted on shelf and the shelf was loose. A couple of screws in it helped a lot. Plus the pipe insulation. Also, in 2004 I think they were using rigid pipe connections to the pump (that were in 2007). Change them to flexible hoses.
2019 Ford Expedition Platinum
10-21-2016, 02:18 PM
Groveland
Noisy Water Pump
Also try this simple fix.
Tighten the two Phillips screws holding the chrome escutcheon (plate) behind the shower handle.
This will also tighten the mixing valve on the other side of the bulkhead.
The mixing valve vibrates when the pump runs.
