Old 03-30-2008, 10:16 PM   #1
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Noisy water pump
I would like to isolate my water pump as it is bolted to the trailer floor and vibrates when being used. I have added an accumulation tank so it doesn't run so often but I would think that by adding some method of isolation from the floor, it would not be so obvious when running. Anybody have any good luck with rubber grommets, isolation boards, etc?
altamont is offline   Reply With Quote
Old 03-30-2008, 10:59 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I made it better, but not absolutely quiet....I don't think that's possible.
Mount the pump to a board and isolate the board by placing foam under the board.
Place foam between the water lines and any contact points.
That should help, if not cure it.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-30-2008, 11:39 PM   #3
cosmotini's Avatar
2021 27' Globetrotter
Saint Louis , Missouri
Images: 83
This SHURflo Pump Silencer may help too. I did the same thing by going to Lowe's and getting some flexible faucet hoses and adapters.
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 03-31-2008, 12:05 AM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I have a ShurFlo Whisper King pump. They cost a couple of bucks more, but mounted to the floor, under the goucho in our Caravel, it is smooth and quiet. Very quiet. There is almost no vibration in the system.
Love it.
Old 03-31-2008, 06:18 AM   #5
Silverhobby's Avatar
Greeeneville , Tennessee
Mounting a layer of EPDM rubber under the base can lessen the vibration significantly.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 03-31-2008, 07:58 AM   #6
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
I used a mouse pad from my computer - works like a charm.
Also, the Shur-Flo pump silencer that COSMOTINI recommends is good - the pump manufacturer recommends flexible tubing at the pump - the AS factory uses rigid tubing. This kit goes on in less than half an hour.
Best of luck!
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 03-31-2008, 09:07 AM   #7
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
A lot of my noise came from the output line bangin against the floor. I restrained it and the noise significantly reduced. My output line already was a flex line.
Michelle TAC MT-0
Sarah, Snowball
Old 03-31-2008, 10:13 AM   #8
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
Here's the solution I used in our previous SOB...attached 10' of coiled high pressure flexible tubing on the output side of the pump to absorb the pressure wave before it hits the hard PEX tubing, and remounted the pump on medium density flattened hot water pipe insulation. Total cost $10 bucks.
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 03-31-2008, 01:36 PM   #9
altamont's Avatar
Tracy , California
Thanks to all. I will try most of the replies in one way or another. That should make it whisper quiet.
New water Pump noisy adonh Water Heaters, Filters & Pumps 10 03-13-2008 12:25 AM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Noisy water pump yukionna Water Heaters, Filters & Pumps 5 04-26-2004 06:11 AM
noisy water lines kooblekidz Airstream Motorhome Forums 1 08-03-2003 01:35 PM
