Old 07-17-2011, 12:23 PM   #1
steel/aluminum fabricator
2004 22' International CCD
Penticton , British Columbia
Noisy pump? Check this out.
So my 04 22' ccd has had a noisy water pump or its probably just normal pump loudness. Probably one of my biggest beefs with the airstream. I decided to install an accumulator so the pump does not come on all the time. Installing that helped a bit. But was still not acceptable. So i decided to tear it all apart and start fresh. Here is the line going to the pump as installed by the geniuses at airstream. You will notice 5, 90 degree elbows which i replaced with 1 flexible line. Also after the accumulator i installed another flexible line outputting to all fixtures. Vast improvement. The accumumlator now works much better as i can run my tap for about 5 seconds before the pump will even come on. Might try this if your airstream pump noise is not to what i think should be airstream standards.
Enclosed for your viewing pleasure.
zedex is offline   Reply With Quote
Old 07-17-2011, 01:37 PM   #2
1994 30' Excella
Mississauga , Ontario
I guess their plumber gets paid by the fitting.
Al and Jean
TAC ON-3
Old 07-17-2011, 01:40 PM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Thank you, zedex.
Ahab is offline   Reply With Quote
Old 07-17-2011, 02:23 PM   #4
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
The els were probably needed to go around the square column holding the roof over the pump!!!! HA! HA! Not to make lightly of the whole thing.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-17-2011, 04:22 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That's where the assembler was kneeling while plumbing the water pump. He had to get around the spot where he was kneeling.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
moosetags is online now   Reply With Quote
Old 07-17-2011, 04:37 PM   #6
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Zedex,
Do you have a picture of the final installation??
David
10Smiles is offline   Reply With Quote
Old 07-17-2011, 04:38 PM   #7
lol. Those pesky knees get in the way every time. A guy with an IQ could have run a straight pipe behind the waterpump bracket with one 90, up to the pump. Unbelievable. Its a good thing it happened though cause otherwise what would one talk about?
David. No i dont have a pic but i guess i could pull off the panel and take one.
Old 07-17-2011, 04:43 PM   #8
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
And I believe that the manufacturer of the pump actually RECOMMENDS flexible lines instead of rigid! We installed flexible lines and it makes quite a difference - so does putting a rubber pad or bushing between the pump and the wooden floor - I used an old mouse pad.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 07-17-2011, 04:57 PM   #9
Complete install with flexible lines.
Old 07-17-2011, 05:53 PM   #10
10Smiles's Avatar
2005 30' Classic
Thank you for the picture... It looks like a nice installation.
Old 07-17-2011, 09:12 PM   #11
Thanks David.
Old 07-21-2011, 10:03 AM   #12
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
Question While we're talking about water pumps.......
That looks like a great improvement to the water pump.
I have been having a problem with my pump and instead of starting a new thread, I will tag on here - I have a 1992 Excella. When I run water, SOMETIMES the pump will not stop running. I can usually get it to stop by running the cold water at the kitchen or bathroom and a bunch of air comes out - then the pump sound swells to really loud and finally it shuts off. WHAT IS UP WITH THIS???? There is water in the tank - could it be that the intake hose isn't far enough into the fresh tank?
I keep trying to think about what it could be - thought I'd ask the experts. I have NOT examined the pump itself - only owned the trailer for 2 weeks and still learning.
I DID, however, have a problem yesterday - all of a sudden (like within minutes), the bathroom sink would give only a trickle of water. Everything else was running with great water pressure. I took off the screen/bubbler thing under the tap and it was full of something that looked like broken shells and sand....I cleaned that out and all is well now.
Could that have been the pump problem?
palmtreegirl is offline   Reply With Quote
Old 07-21-2011, 10:26 AM   #13
Excella CM's Avatar
1978 31' Excella 500
Venice , California
PTG
Sounds like air is getting into the intake. The pump wont compress air. May be a loose connection between the fresh water tank and the pump.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-21-2011, 12:18 PM   #14
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
How about replacing your current pump with shurflow variable pump, which is lot quieter than the factory installed. I baught one for $129 and the change over was very simple in my 20 footer under the oven.
Zia is offline   Reply With Quote
Old 07-21-2011, 01:22 PM   #15
2005 30' Classic
Burlington , Ontario
The bearings in my original Aquajet pump seized up. The pump had always been extremely noisy since we bought the trailer - and for all the racket it made, didn't put out a whole lot of H2O.
When I removed the pump I order to diagnose the problem, I found that it had a loop of flex hose in the outlet side, but hard piping right up the inlet filter - contary to Aquajet's installation instructions.
After I found the problem with the pump (seized bearing) I emailed Aquajet to see if I could buy parts. Two emails - no replies.
I then decided to just buy a new pump. Local RV dealers only had Shurflo in stock so that was what I wound up with - rated flow slightly less than the Aquatec Spec. I installed wit flex hoses on both sides of the pump.
The new pump works a treat! Almost silent and greater water flow than we ever had with the old one - all's well that ends well.
Brian.
Old 07-21-2011, 08:25 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think you have a leak on the suction side of the pump. If there are rubber hoses connecting the tank to the inline filter and then to the pump; they could be old and dry allowing air to etiher get in at the fittings or simply through the hose wall.
Replace any and all hoses on the intake side of the pump making sure that the connections are tight.
Old 07-23-2011, 07:13 AM   #17
Medina , Ohio
Thumbs up Got to find the pump.
OK, I'm going to try to locate the pump - I think it is in the closet under the floor (of the closet). That is where I hear it all the time. I'll see what I can find and let you know what I see (or take a picture). Thanks!
Old 07-23-2011, 09:09 AM   #18
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Mine made noise too. But it was the pump moving the pex pipe I put in. Even though it was tied with pipe brackets. I bought some of the foam pipe insulation. Put it in the bad spots and now it's nice and quite again..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-23-2011, 01:51 PM   #19
Medina , Ohio
Found the pump - picture here
OK, I found the pump - the far (in the picture) hose fitting seems a bit loose but when I try to tighten it the whole pipe system, elbow, etc. moves....
Old 07-23-2011, 01:59 PM   #20
Medina , Ohio
It is a Shurflo pump - not sure what the thing on the right is.
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 06:01 PM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 07:56 PM
MH check up. To-do-list Octane General Motorhome Topics 9 04-14-2011 03:36 AM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 07:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 08:20 AM
