09-17-2018, 05:09 AM
2018 16' Sport
Lynn Haven
, FL
No gas going to 16 Sport water heater
My Sport is a new 2018 with zero trips logged. I'm familiarizing myself with all the systems and backyard camping for now. I have gas flowing to the stove and have water in the water heater. When I hit the electronic ignition I can see the igniter firing but there is no gas present in the combustion chamber to ignite.
What am I doing wrong?
Thanks, Steve
09-17-2018, 05:22 AM
2015 16' Sport
Lakeridge
, Virginia
Steve - does the red light next to the water heater on/off switch stay on? It is supposed to come on if the heater doesn't ignite. Same thing for the red "check" light on the refrigerator when running on propane.
09-17-2018, 06:26 AM
2022 25' Flying Cloud
NCR
, Ontario
bad board
get a replacement dinosaur broad and get AS to pay for it
that what i did
now no problems after multiple bad OEM boards
lots of thread on this issue
09-17-2018, 07:44 AM
2016 16' Sport
Miami
Before jumping to board replacement check the thermal cutoff. They do go bad. You will see it plugged into the board. It’s a diode (I think) inside a plastic tube bent at a 90 angle. Disconnect both wires to the diode and put them together thus bypassing the diode. A blade fuse works great to connect the two wires.
If it starts tthe that’s your problem and a cheap fix.
09-17-2018, 07:50 AM
2018 16' Sport
Lynn Haven
, FL
Thank you folks I will try the additional trouble shooting and let y’all know how it goes.
09-17-2018, 03:44 PM
2018 16' Sport
Lynn Haven
, FL
Well I bypassed the the diode and still the gas valve isn’t opening. I suppose the board is bad. It would have been nice for the dealer to actually test everything before I drove off with it. They had a full week before delivery. I can tell this thing has never been lit.
09-17-2018, 04:40 PM
2016 16' Sport
Miami
Too bad. Hopefully if you call them they will reimburse you for a board without a trip to the dealer. If your in a rush just order the board from Dinasouar and eat the 100 bucks.
09-17-2018, 04:43 PM
2018 16' Sport
Lynn Haven
, FL
Thank you for your help! I will call airstream and see what they will do. My dealer is 5 hours away and I don’t trust them anyway sadly.
09-18-2018, 12:02 PM
Airstream Ambassador
Jackson Center
, Ohio
Thanks, Steve
Hi Yaak18,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
09-21-2018, 04:34 AM
2018 16' Sport
Lynn Haven
, FL
Emailed Customer Service
Originally Posted by AirstreamInc
Hi Yaak18,*
Thank you.*
I emailed customer support on 9/17/18
10-03-2018, 07:38 PM
2018 16' Sport
Lynn Haven
, FL
Well, Airstream sent me a new OEM board and it doesn't work either! I assume this will be a long drawn out problem with them sending more faulty boards to me to test rather than sending me a tested board or a Dinosaur board as I requested.
