02-05-2008, 04:03 PM
#21
1976 25' Caravanner
Campton
, New Hampshire
I would say that you are correct with your assumptions.
The pump acts as a check valve to prvent city water from going into the tank.
There should be a check valve where you found the hose splice to prevent the pump water from going out the city connection.
The coil spring in the hose is to prevent it from collapsing with suction
The pump staying on is probably a small leak in the suction line . ( Did it have a hard time getting prime?)
It could also be a faulty pressure switch on the pump.
03-26-2008, 01:11 PM
#22
1985 25' Sovereign
Valley Center
Once again, the fine people on this forum have helped me out…
The cycling pump issue was caused by a small leak in the suction line. Upon further investigation we found that our pump was showing signs of age so we replaced it and added a Shure Flo accumulator tank into the system. Now we have a quieter pump that runs less frequently. We replaced the flex lines, too, but did not reinstall the stainless coil springs inside the hoses. They seem to work fine without them.
We installed a city water check valve, SOB style, where the hose fitting was.
Our ’84 Sovereign has hot and cold water PEX T-handle drain valves installed in a chase below the kitchen sink. This chase goes all the way through the floor – you can see the back side of the belly pan access cover if you peer through.
We also found a fresh water tank drain plug behind the belly pan access cover. The plug was gooped into place with ½ a tube of white silicone. We cleaned it and reinstalled with Teflon tape, followed by Teflon paste. Now it doesn’t leak.
I hope this information can help someone else.
03-26-2008, 01:59 PM
#23
1976 25' Caravanner
Campton
, New Hampshire
Glad you got it fixed . Everything we learn and share helps someone else , thanks for posting results.
04-14-2008, 08:47 PM
#24
Water line woes
When is the lawsuit over the Polybutylene (gray and black tubing) used for fresh water supply deadline? I read about it (searched internet) but am unsure of it's meaning pertaining to travel trailers and motorhomes. Seems it depend on the installation, usage and whether damage was done. Doesn't cover just replacing prior to failure...from what I can interpret.
Polybutylene pipe is a plastic developed for use as a plumbing product by Shell Oil Company. There are a few problems associated with polybutylene. These problems are associated with homes built from 1/1/78 to 7/31/95. Most areas have banned the use of polybutylene. There are some class action law suits against the manufacturers as well as the installers and are trying to settle the damages. One has been settled for 950 million dollars and the fund will remain open until the year 2009 or 16 years after date of installation, which ever is soonest. For information on claims call; 800-356-3496, they will send you a form and if you qualify an Inspector will be sent to evaluate the conditions. to make a claim there does have to be a leak of failure of the product. For commercial claims or multi unit dwellings contact 800-876-4698.
Exterior; Big Blue, Vanguard Claim must be within 11 years of installation The supply line from the outside is sometimes referred to as "Big Blue, and may be identified by its light blue color. This type of polybutylene is susceptible to shearing at the foundation wall due to ground settlement outside. One recommendation is to sleeve the pipe through the wall for additional reinforcement. Another recommendation is to simply replace it. The plastic is also reported to break down due to elevated levels of chlorine, there has not been any established time frame for this to occur.
INTERIOR; Vanguard Claim must be within 13 years (acetyl fittings), 16 years (metal fittings) of installation Interior polybutylene is identified by its gray color. When this product first came out the ends were connected by metal barbed connectors, that were held in place with a copper crimped band. The metal fittings were overall adequate. Later plastic barbed fittings were introduced. These fittings were prone to cracking off and failing, due to crimping of the copper or aluminum bands, and could allow water to free flow. The plastic fittings may develop hairline cracks from the pressure of the crimping and should be replaced with approved metal fittings. In some areas highly acid water can deteriorate copper pipe in a relatively short time, or burst due to freezing. Polybutylene is virtually unaffected by these conditions. Why don't they pull copper off the market as well? Polybutylene has a good flow rate, is more impervious to freeze, and has fewer connections. We should be aware of its problems but know its strengths as well. *Note: Some information has been taken from Cox vs. Shell Oil, et al.
Has anyone sought replacement from AS for using this product or applied for reimbursement from the Class Action Law Suit?
06-19-2008, 07:00 PM
#25
1980 28' Excella II
Schuyler
, Virginia
thanks, this should motivate me to start work on water pump on my 80 AS. the pump is running, but water is Not come out at faucets.
