Old 12-26-2009, 06:00 PM   #1
2006 25' International CCD
Tucson , Arizona
New Water Heater for 2006 25' International CCD
AZ AL here, looking for advice on the best water heater for the 2006 25' International CCD. Mine is tired (very tired) and needs to be replaced. Not sure the best water heater to get.
Arizona Al is offline   Reply With Quote
Old 12-26-2009, 06:45 PM   #2
Ottawa , ON
I'm amazed that an '06 could need a heater already. What happened to yours?
Is it the original one?
I just replaced my 36 year old Bowen with what is really the same one, but now branded Atwood. I figured that if the old one lasted 36 years, why wouldn't another one of the same type...?
Old 12-26-2009, 07:01 PM   #3
Tucson , Arizona
2006 25' International CCD - Water Heater
Aage, it is a long sad story...
I bought the CCD used and the previous owner must have run the water heater 24/7. It has no controls on it...0, and it will not keep the water hot, and O yeah it leaks a bit. It appears to be the original unit but it has no branding on it...can't find a name anywhere.
I need a new good one.
Thanks...AZ AL
Old 12-26-2009, 07:14 PM   #4
Ottawa , ON
Wow, incredible. Well, post a photo, but IIRC, they're all Atwoods these days.
I mean, to my knowledge, there's only Atwood and one other company (whose name escapes me at the moment) that makes them, and the other company's products orient the tank into the TT, and so would require big changes to mount...
Old 12-26-2009, 11:23 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I'm shocked that you need a new water heater already unless it was freeze damaged. I would, if I were you, order the same thing, but with the 120 volt option.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-05-2010, 09:16 PM   #6
Tucson , Arizona
New News
All, it turns out that the newer Airstreams do not have temperature controls on the water heater as they are electronically controlled, you can control the water temperature somewhat by using a mixing valve that is on the side of the water heater accessable on my CCD via the side storage compartment. Mine was wide open allowing the cold water to mix with the hot and cool it down too much. My leak was a loose drain plug. All is well with Al...Arizona Al
Old 01-05-2010, 09:49 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Whew! You had me concerned...ours is also an 06 and we have had no problems... thanks for pointing out the cold & hot water mixing valve...I did not know that! Glad you have hot water now!
TB & Greg and Abbey Schnauzer
#3954
Old 01-05-2010, 09:51 PM   #8
Salem , Oregon
Images: 18
Hi, we always like happy endings.
2005 Safari 25-B
2006 Airstream International CCD New Color Colonial Airstream Commercial Listings 24 07-04-2009 10:10 PM
2006 Airstream 28 INTERNATIONAL CCD eBay Watch Airstreams on eBay 0 05-30-2009 11:10 AM
Considering a 22' or 25' International CCD DiscoBall 2002 - 2005 International 7 03-11-2005 09:57 PM
