Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-24-2008, 08:35 PM   #43
Sunset Coast
Sunset Coast's Avatar
Profile:  1988 32' Excella
Benton Harbor , Michigan
Used my old heat shield
Jim,
I cleaned up my old heat shield and it mounted onto the new heater. The new heater has slots on the left side of the plenum and a screw hole on the right side (just below the ground wire screw). It was a snug fit but works well. Hope this helps.
Doug
Name:	Water Heater Replacement 085-2.JPG
ID:	60930   Click image for larger version
Name:	Water Heater Replacement 086-2.JPG
Name:	Water Heater Replacement 087-2.JPG
Sunset Coast is offline   Reply With Quote
Old 05-25-2008, 07:45 AM   #44
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Hey Doug,
I may wind up doing that. I thought I'd read in an earlier posting that you or one of the other guys had mentioned doinng that. My old one is kind of "burnt" looking so I was hoping to make the new one work. No matter, later today, one of them is going to work
On a side note, don't you need to remove that red plastic plug from the safety blow off valve? I thought that was just a thing for shipping etc they stuck in them at the factory. Or, is that plug supposed to blow out when cracking pressure is reached? I was gonna pull mine out and pitch it...
thanks!
- Jim
JimGolden is offline   Reply With Quote
Old 05-25-2008, 10:04 AM   #45
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
I kept the red plastic liner in because it isn't really a plug. It is open to allow water flow, so I figured there was a reason for it being there. Also, I couldn't find anything in the instructions saying to remove it.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
cameront120 is online now   Reply With Quote
Old 05-25-2008, 12:26 PM   #46
JimGolden
JimGolden's Avatar
Thread Protector
Yeah, I discovered it's got a hole in it when I pulled it out.
It's nothing more than a thread protector.
It works now! Dad and I tried to wire it up so that you just flip the breaker for electirc and use the original switch for LP, but it wouldn't work like that. You have to have 12V all the time for the control board. So you cannot run 110v without the 12v being operational as well.
So I wound up using the new switch, but it's on a board mounted inside the closet. It's a temp rig, but will work to get me going. I'll relocate it to a better area later. I'm taking the rig camping in a couple weeks and I need it to work. Got that now
- Jim
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 05:14 PM
hot water water on demand with a with a normal water heater 62overlander Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
81 excella water heater nightowlhooter1 Water Heaters, Filters & Pumps 6 08-20-2003 09:52 AM
