Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 09-18-2009, 07:19 PM   #1
pigsfly's Avatar
Profile:  1961 26' Overlander
Gastonia , North Carolina
New water heater?
I want to upgrade the hot water heater in my 61 Overlander International.
Is there a standard replacement for the old ones that will fit into the old space?
pigsfly is offline   Reply With Quote
Old 09-18-2009, 10:05 PM   #2
camper collector
Profile:  1997 30' Limited
Americus , Georgia
Take out your old one and measure the opening then google the website for Atwood Hot water heaters or Surburban Water heaters and each site will give you the size opening you need for the model you pick.In some cases you may need to add an aluminum filler to close the hole up if the heater is smaller that the opening.
Have fun while you are doing this,don't let it be work---
"I can do all things through Christ who gives me the strength" Phil.4:13
Camper
camper is offline   Reply With Quote
Water wood rot under toilet and water heater! Mrcrowley General Interior Topics 4 12-01-2008 03:34 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 05:14 PM
hot water water on demand with a with a normal water heater 62overlander Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
