Old 03-15-2012, 08:37 PM   #1
musicmaster's Avatar
1976 31' Sovereign
Greenwood , South Carolina
New W/H - Old Door
I have install a new 10g water heater in my A/S to replace the old 10g model. The problem is the door. The new one was only available with a white door. I had planned to use the old door but it attaches differently.
Any suggestions ?
musicmaster is offline   Reply With Quote
Old 03-15-2012, 08:40 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Any suggestions ?
Modify the water heater so the old door will fit. It's not tough, though it does require a bit of engineering.
Old 03-15-2012, 10:25 PM   #3
1973 31' Excella 500
Marysville , Washington
Overlander said it exactly...
Not Done is offline   Reply With Quote
Old 06-10-2012, 07:41 PM   #4
Ottawa , ON
Terry, you have said this before, so I got my old door out and looked at it to see how involved it would be.
First thing I noticed? The new Atwood has one clip holding the door closed. The old door? You guessed it, two clips. So cut two holes, patch up one. Check.
Plus the hinges are in a different spot.
That's when I just took off the new door and gave it 4 or 5 coats of rattle-can auto paint silver, with 2 coats of clear over that.
If you would be so kind, perhaps you can point to where you might have laid out the instructions on how to adapt the old door, or failing that, could you write up a post on it?
After looking at my new (painted) door, looks pretty good. I know the older SS door would be an improvement, but I don't see the conversion job as trivial.
Maybe I'm missing something? Wouldn't be the first time...
Old 06-10-2012, 10:50 PM   #5
Silver Spud
shadrick5's Avatar
1975 31' Sovereign
Twin Falls , Idaho
i currently have the same issue. I want to use the old ss door but the new Atwood is configured completely different including the way the old had an attachment flange around the unit that butted up against the side the alum skin. The new one is a flush mount that I haven't quite figured out how it is supposed to be a direct replacement, although I have yet to pull the old out to see.
shadrick5 is offline   Reply With Quote
Old 06-10-2012, 11:02 PM   #6
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
On my 1967 ( which is no doubt different) I was able to use my original cover. The cover screwed right back on. What was different was the inside panel, it took a bit of rework to fit to the new Suburban water heater I installed. From the outside it looks original.
Fortune cookie say....."Prudence keeps life safe, but does not often make it happy."
Diesel1 is offline   Reply With Quote
New Airstream Mhenry2712 Friends of Dorothy 75 11-23-2013 04:14 PM
New LED light kit with sealed lights Dan@LED4RV Commercial Listings 18 08-27-2012 12:18 AM
Anyone know where to find the outside access door hinges? Roothawg Vintage Kin 10 05-13-2012 05:21 PM
Getting Safari 'off the ground' for new axle. SafariFaye Axles 9 03-18-2012 05:16 PM
94 Airstream CLASSIC EXCELLA 30 FT SLEEPS 6 NEW TIRES eBay Watch Airstreams on eBay 0 03-15-2012 08:20 PM
