Old 04-11-2014, 08:43 PM   #1
1973 23' Safari
sequim , Washington
new w/h.. Attwood or Suburban?
We're replacing the water heater. Six gallon. Which of the two brands is favored for any particular reason? '73/23' Safari
sunnynsequim is offline   Reply With Quote
Old 04-11-2014, 10:31 PM   #2
1974 Argosy 20
Kooskia , Idaho
They are different size, so get the one which is essentially the original one, the Atwood. It will fit right into the original hole. The gas line location will need to be changed, as the new Atwood has the gas line coming through the side, not the floor like your original one. Most just drill a new hole in the case for the floor installation, but if you wish to use the side location on the new heater, you will need to change some gas piping around.
You can get an original pilot light one, an electronic ignition one (DSI) or one which also has an electric heating element plus the DSI. I recommend the DSI unit, much nicer to turn the water heater on and off with a switch than go outside and light it. You will need 12 volt power for the DSI unit. If you go the full woot with an electric heating element, you will need to do both 12 volt wiring and 120 volt wiring with a new 120 volt circuit.
I hope that helps some.
Old 04-12-2014, 04:30 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The Suburban requires a lot of work in order to cobble it in an Airstream. Also, the initial price of a Suburban does not include the door assembly. By the time you buy the door assembly, the cost is almost the same, and you are still stuck with trying to make it fit in your trailer.
Stick with the Atwood.
Old 04-12-2014, 05:23 AM   #4
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Easiest is to replace with same brand that was already there. I used the stainless door from my 34 year old Atwood because the new one is white. Bolted right on no problem was even able to use the vent screen from the new one on the old door.
thehandyman is offline   Reply With Quote
Attwood Water Heater issue redux jkinglet Sprinter and B-van Forum 3 09-10-2014 05:22 PM
Attwood on demand delayed AGAIN wharfrat8995 Water Heaters, Filters & Pumps 1 05-29-2012 11:04 AM
196O Overlander buying an Attwood furnace? Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-07-2010 12:51 PM
Attwood Water Heater... Trouble Shoot... Lothlorian Water Heaters, Filters & Pumps 9 12-31-2009 12:22 PM
Attwood heater stinks, then dies! Gasp! Anniedog Water Heaters, Filters & Pumps 0 10-17-2007 07:00 PM
