Old 09-04-2010, 07:53 PM   #1
Clarksville , Tennessee
"New to us" '05 Safari water pump
Recently purchased a 2005 Safari Bunk. We tried to "boondock" in our driveway and the water pump won't come on. I checked the fuse and it seems to be fine. The venthood runs on the same fuse and it comes on fine. Its there anything else to try before pulling the pump out?
Joshthemule is offline   Reply With Quote
Old 09-04-2010, 08:37 PM   #2
tpi
Trabuco Canyon , California
I'd turn on pump and run the pressure out of the water lines. Then go to pump and confirm I had 12 volts at the pump. If so I'd give it a tap or two and see if it starts.
If it has the 12 volts, has no pressure in the lines, and won't start I can't think of any other option but to replace the pump.
tpi is offline   Reply With Quote
Old 09-04-2010, 08:59 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Do you have water in your white tank?
I should mark that switch OFF/ON side on my unit - Every time I use it I have to experiment to remember which position is which.
I think mine won't run for more than a second if the tank is dry. Of course the PO may have burned it up.
If there's water in the tank and the pump doesn't come on when you open a faucet, I'd look for a wire loose on the pump, then determine if it's jammed or burned out.
paula
Old 09-04-2010, 10:00 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
paula
Hi, I have no idea why they didn't put a light , or mark the switch so we can tell if it is on or not; When the other two switches are in the on position, this switch is off? Future project, add a light or something.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-04-2010, 10:17 PM   #5
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
If you need a new pump (I hope you don't), you might want to try one of the "new" (in the past year) Shurflo "Revolution" pumps, I put one in this summer. Works great and it's rather quiet. Doesn't hammer like my old pump and it's quieter than the Shurflo that was in my Jayco.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 09-12-2010, 07:04 PM   #6
abolton's Avatar
2002 19' Bambi
dallas , Texas
If the inline filter is overtightened the pump won't work. Mine did the same thing and I was loosening filter to bleed it, and as soon as I loosened it the pump started running. Never had another prob from it.
abolton is offline   Reply With Quote
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
