Old 01-21-2013, 11:29 AM   #15
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Hi, no it doesn't stop, and the laboring doesn't sound good. I'll look for the adjustment screw, that seems like the best place to start. I replaced the pump last year, then had the Univolt replaced with a new gizmo and got a brand new AGM battery and some wiring was corrected. It was hooked to shore power anyway. I had filled the water heater through the city water inlet, then filled the tank. I think I've covered all the variables people have mentioned. It really is laboring against pressure, so I think the switch is the place to start. If not that, then I can fiddle with the grounding. Fortunately, it's an older one and the wiring is simple. Maybe it's also just a weak ground, a loose connection to ground?
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Winterizing & Water Pump Access 27FB DMT Winterizing, Storage, Carports & Covers 28 11-17-2011 06:15 PM
Fridge not working with Gas, still works w/electric Tim_S Refrigerators 3 09-02-2011 05:06 AM
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 05:01 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
