Old 01-20-2009, 08:48 PM   #1
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
New Pump
I Need to install a new water pump. When I purchased this A/S the PO said that the pump had been broken, he took it out, and threw it out because he was selling it. In other words, I don't know what was in it. Anyone know what make and model to use?
Stone Ridge is offline   Reply With Quote
Old 01-20-2009, 08:57 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
New Pump
Greetings Stone Ridge!
If you are inquiring about the pump for you 1976 coach, it was in all probability a Peters and Russell pump. They are still available new, but rather expensive -- I think that they are well worth the money since the are rebuidable and can last three decades or more with good care and the ocassional rebuilding.
I had to have a new pump when I bought my Overlander in 1995 (the coach's previous owner had completely removed the original pump because "it wasn't working") -- didn't question going with a PAR and I am thrilled with its performance and durability. My Minuet has its original PAR and has been rebuilt once since I bought the coach in 2002.
Kevin
Kevin D. Allen
AIR #827
Old 01-20-2009, 09:03 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I put a Shurflow in a SOB that I had before we got our Trade Wind. I put the same kind of pump in the AS 3 years ago and it works great.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 01-20-2009, 09:36 PM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
PARs are loud, go with Shurflow, new technology good, old technology, well ......old.
smily is offline   Reply With Quote
Old 01-21-2009, 06:47 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I put in a Camping World Flowtech pump. It uses the same design as Shurflow but is cheaper, since they do not spend as much on advertising. It is smaller and quieter than the old PAR type pump. Frequently on sale for less than $60.
Old 01-21-2009, 08:28 AM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
While you're at it, install an accumulator.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 01-21-2009, 09:16 AM   #7
1976 31' Sovereign
1963 16' Bambi
Accumulator
What is an accumulator and what does it do?
Old 01-21-2009, 09:41 AM   #8
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
See Shurflo Accumulator Tank - Item - Camping World and Shurflo 2-Gallon Stainless Steel Tank - Item - Camping World. By compressing air in a bladder in the tank, pump cycles are reduced. Well systems use the same thing on a much larger scale.
Vaughan
vswingfield is online now   Reply With Quote
Old 01-21-2009, 10:12 AM   #9
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Much good advice here, I would go with the sureflo and the accumulator you will be well pleased. Take time to sound isolate the pump. that is put some rubber under the pump to keep the sound from traveling throughout the trailer and make certain the tubing coming out of the pump is not against the structure of the trailer. good luck
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 01-21-2009, 01:25 PM   #10
1963 24' Tradewind
San Diego , California
The SHURflo Whisper King is quieter than the standard SHURflo and has a 5 yr warrenty instead of 2 yr. Maybe $25. more
Sixty3TW4US is offline   Reply With Quote
Old 01-21-2009, 06:39 PM   #11
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Pretty much any water pump will work, some are better than others. You don't need a pump specific for Airstream . I have a Sure Flo and no complaints.
Old 01-21-2009, 08:12 PM   #12
CanoeStream's Avatar
St. Cloud , Minnesota
lewster will message with you if you open his profile and get in touch. He's not following & responding to threads right now. But take a look at http://www.airforums.com/forums/f443...tml#post430032. And scroll back to post #20. He seems to say current pumps don't require an accumulator. I've got a noisy PAR pump and am taking way to much time to follow Lew's advice.
5 meter Langford Nahanni
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 03:01 PM
No Prime, or no pump? blaisew Fresh Water Systems 5 12-14-2007 01:38 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 11:11 AM
Water Pump - 2004 Classic jcanavera 2001 - 2005 Classic 12 06-26-2004 10:56 PM
water pump nwclassic Water Heaters, Filters & Pumps 3 12-15-2003 07:26 PM
