Old 02-12-2012, 12:14 PM   #29
lewster's Avatar
Marco Island, FL , Hood River, OR
Originally Posted by mutcth View Post
Referring back to an earlier question, how much of a current draw is there for the instant ignition? Not a fan for parasitic loads when boon docking...
And how exactly do you winterize them? Is there anything to drain out?
Another thing to add to the list of future toys...
Tom
The DC loads are approximately the same as a conventional DSI tank water heater....not much! Thee might be a small circulating fan that will use some DC (perhaps less than an amp) while the unit is operating.
Winterizing is done like anything else; run pink propylene glycol RV antifreeze (PG) thru all hot and cold water lines until it comes out all of the faucets, ice makers, washer/dryer lines, etc. Add some PG to your p-traps and toilet and you're done.
As there is no water storage tank in the water heater, there is no need for a by-pass system. just be sure that the PG flows thru the copper coils in the water heater's heat exchanger, as it will if you have PG coming from your hot water faucets.
Lew Farber -RVIA Nationally Certified Master Tech.... MASTER TECH RV SYSTEMS, INC.
AM SOLAR SALES & INSTALLATIONS .....MAGNUM INVERTERS.....LIFELINE BATTERIES
NO MORE AIRSTREAM.... NO MORE MEMBERSHIPS....BUT I'M STILL AROUND!
lewster is online now   Reply With Quote
Old 02-12-2012, 06:47 PM   #30
Vintage Kin
REDNAX's Avatar
Corpus Christi , Texas
(I always liked the cheap case of vodka as an alternative to the pink stuff as mentioned years ago by someone here).
Thanks for the info on these heaters.
2004.0 DODGE 2500 QC/LB Cummins 305/555; 6-manual, 7,400-lbs; fuel cost is 25-cpm towing 34' trailer; 15-cpm solo.
Sold: 1983 Silver Streak 3411 Supreme; 6,860# (8,000 GVWR) Currently: 1976 32' SS
Photos prior to sale
REDNAX is offline   Reply With Quote
Old 02-13-2012, 05:44 AM   #31
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Send a message via ICQ to Skater Send a message via AIM to Skater Send a message via Yahoo to Skater
A woman in our local unit wants to try this. Of course they just built a heated garage that can store both of their trailers, so it's a moot point for them now.
Back to the tankless - I'm following this thread with interest, too, and can't wait to hear what people say about them after using them a while.
As it stands now, I usually turn off the water heater during the day and at night, only turning it on in the morning before we officially get out of bed (I get up early to feed the cat, then crawl back in bed, so I usually turn on the water heater then), and we'll turn it on before dinner so we have hot water for dishes. As others have noted the tank will keep the water at least warm enough for washing hands and the like the rest of the time.
Given that usage scenario, a tankless isn't going to save a lot of propane and may actually use a bit more. The advantage of the tankless would be not having to worry about switching it on and off, yet still having hot water at any moment.
The point that the water doesn't come out at a specific temperature was an interesting one - it only raises the water temperature a certain amount, so if your input water is very cold, your "hot" water isn't going to be as hot as usual. I've read stories from people with them at their houses that had very cold incoming water, so the tankless WH didn't do very well for them. This is an important point for me, because we camp in the winter weather as well, and water coming out of our fresh water tank in the cold weather is VERY cold, so the tankless WH might not be a good idea for us in the camper. (I still think it'd be great at our home, though.)
(On the other hand, this winter, we were having issues with major temperature fluctuation out of the regular water heater as the pump kicked on and off. By "major," I mean "from too cold to too hot without touching the shower handle." So it's not like we're having a wonderful experience with the current setup in winter, either.)
1995 Airstream Classic 30' Excella 1000
B190 Owners: The site B190 Enthusiasts is dedicated to the 1989-1999 Airstream B190.
Skater is offline   Reply With Quote
Old 02-13-2012, 06:10 AM   #32
lewster's Avatar
If you look at any water temp chart that usually comes with a tankless water heater, you can see how hot your output water will be depending on two factors: temps of the inlet water and the flow rate.
Tankless units are rated for a set degree rise at a specified flow rate and inlet water temp. Adjust either of these parameters and you can still get very hot water; simply turn down the volume of hot water coming from your faucet.
Old 02-13-2012, 06:33 AM   #33
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
My concern with a tankless water heater would be if this setup would use more water than the standard water heater. I have been around household tankless heaters and it seems that you have to flow a lot of water before you get hot water at the tap. This means more water from the freshwater tank and more in the grey water tank. I would rather eat more propane versus dealing with more waste water.
Does this make sense?
Steve, Christy, Anna and Scout (Border Collie)
1994 30'11" Excella - rear twin
Hensley with adjustable stinger
WBCCI # 3072
AIR # 6035
crispyboy is offline   Reply With Quote
Old 02-13-2012, 07:29 AM   #34
1994 30' Excella
Mississauga , Ontario
As far as gas consumption goes, we often turn the heater off when we go to bed and turn it on again in the morning. The water is still quite hot in the morning and it only takes ten minutes or less to be at full temp.
The tankless heater seems very expensive. Having 5 gallons of water in the tank actually increases your capacity and if it's an issue don't fill your freshwater tank to the max.
Al
Al and Jean
TAC ON-3
Old 02-19-2012, 06:25 AM   #35
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
My only concern with the tankless heaters for us in the great white north is freezing when using the Airstream in cold weather. The 3/8" copper lines filled with water are exposed directly to outside air so it would not take very long to freeze and split them. I would not be a problem if you were using water steadily but a 4 hour drive in 0 degree weather or 8 hours without running water would do it in.
Though parts of the tank style heater are expose to the outside air it takes a long time to freeze 6 gallons. They did not have an answer to this problem the last time I spoke with them. You could have a circut that would keep firing the heater in cold weather to prevent freezing but if the system stopped working for any reason you would have split lines.
Andrew T
Andrew Thomson
London, Ontario
Andrew T is offline   Reply With Quote
Old 02-19-2012, 10:56 AM   #36
CrawfordGene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
Andrew, very good point. Glad to see you asked them directly.
Perhaps you could put insulation between the heater and the exhaust door, but the danger is someone not remembering to remove it when they turn on the water heater. The only way to make that safe is a switch that to be turned on in that compartment after removing the insulation.
Gene
CrawfordGene is offline   Reply With Quote
Old 02-19-2012, 11:13 AM   #37
TAC AB-2
truckasaurus's Avatar
1960 33' Custom
Airdrie , Alberta
Frank. PT's Showermate (the marine version of the RV500) vents through the floor and is good for venting up to 20' through 2" hose. It has a tiny fan in the exhaust. I bought mine maybe 18 months back and I think it was available for sometime before that. It's a really nice product just a little bit more $s
truckasaurus is online now   Reply With Quote
New atwood gas/absorption fridge lewster Commercial Listings 17 02-25-2012 07:59 AM
tankless water heater dixongary Water Heaters, Filters & Pumps 1 07-24-2011 11:32 PM
Repost of Atwood door sealing Hueytownalss Water Heaters, Filters & Pumps 2 07-09-2011 10:05 AM
Tankless Water Heater lucymcdog Water Heaters, Filters & Pumps 4 07-04-2011 05:00 PM
new atwood 7900-11 furnace help hgut Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-10-2011 05:09 PM
