Old 04-29-2009, 01:32 PM   #1
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Need Water Heater Repl Photos
I've read many threads and have not yet found what I need.
I'm replacing the old original Bowen 32 year old 10 gallon propane water heater and I'm replacing it with he Atwood 10 gal propane heater. I understand that the Atwood fits the hole pretty well, except that I will have to modify the blue trim strip at the botton to accommodate the new heater door.
What I need is photos of the removal process and the new installation and any tips that might make it easier. I have a 76 Sovereign International.
Any one with posted photos or a thread reference?
Thank you, Bill
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 04-30-2009, 10:21 AM   #2
Victoria , British Columbia
Hopefully this helps
Deuce is offline   Reply With Quote
Old 04-30-2009, 11:03 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
close, but"no cigar"
I like the video, now I am searching for the water heater one. I need it too.
Old 04-30-2009, 12:28 PM   #4
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Hey Deuce,
Thanks for the video.......however it is for a "furnace" replacement!
Do you have one for the "water heater"?
Bill
Old 04-30-2009, 01:58 PM   #5
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
I am most of the way done with the same thing, but I had the side body panel the water heater opens thru removed because it was also being replaced, and the bedroom wall too. As far as I remember, I only had to remove the water in and water out connections from inside the bathroom next to the toilet. After that it was just screws & rivets and caulk holding it in from the outside. A heater vent / box thing that is supposed to keep the water heater warm rests on top of it, but I don't remember it being attached.
I have not hooked propane or electricity to the new one yet, and I am gonna have to redo (or maybe just re-bend if I am lucky) the water lines because the bathroom does not want to fit back together the way they are.
Even though I have the same trailer and did teh same replacement, my procedure was probably quite different because I have so much else taken apart. That said here are some pics from removal day WebForm1
chrisd37 is offline   Reply With Quote
Old 05-02-2009, 12:47 PM   #6
FT RVing
lebolewis's Avatar
1976 31' Sovereign
New Water Heater
My new Atwood 10 gal water heater arrived with some minor damage.....bent door and slightly bent front frame......not packed well. The front outside mounting flange is shipped bent at about a 45 degree angle. It must be bent to a 90 degree angle to work....the manual reminds you of this. I found that the easiest way to do this is to insert an ice pick like tool, or simular, in the screw holes, from the back and gradually bend the flange to a 90 degree angle.
Flexible couplings for hot and cold connects and also for the propane connection seem to be the way to go.
Old 05-02-2009, 01:01 PM   #7
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Water Heater Installation
Here is a youtube Video of the installation of a 6 gal water heater that may be helpful to some of you. Bill
Old 05-02-2009, 01:02 PM   #8
FT RVing
lebolewis's Avatar
1976 31' Sovereign
OPPS....didn't send the link!.......
Old 02-08-2010, 11:43 AM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Did I hear that right?
Did they say the power connection to the heater is AC? does that mean the electric ignition wont work unless you are hooked up or is that a dual power unit? Or both?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-09-2010, 06:10 AM   #10
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
My Atwood water heater plugs in to a 120v AC outlet for electric mode water heating. It also attaches to my 12V DC bathroom light bulb circuit, I am assuming for electric ignition of propane and for the lockout light (although I have never tried using propane mode).
Old 02-09-2010, 06:49 AM   #11
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
120v AC powers the element,12vDC powers the ignition.
easyride is offline   Reply With Quote
Water wood rot under toilet and water heater! Mrcrowley General Interior Topics 4 12-01-2008 02:34 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 04:14 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
