Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-14-2007, 03:50 PM   #1
pdfr67
Profile:  1977 28' Argosy 28
citrus heights , California
Need to replace water heater in '77 argosy 28'
Water heater appears to be leaking in '77 argosy 28' rear bathroom. It appears that the gas line and water lines need to be disconnected then it comes out as one peice by removing screws in the outside access door.Are there any tricks or anything I need to be aware of? Also were do I find a new one or a used one in good condition?
Thank you for your help!
pdfr67 is offline   Reply With Quote
Old 05-14-2007, 04:24 PM   #2
drag'nwagon
drag'nwagon's Avatar
Profile:  1974 31' Sovereign
1956 26' Cruiser Overlander
Lambertville , Michigan
I just did one in my '74 AS 31'. Yes, disconnect gas line, undo plumbing, unscrew from outside. I have heard that some have a mounting bracket under the tank but mine did not. Removal is pretty easy once you cut through the caulk and sealants. For replacement I went to camping world outlet center in Bowling Green KY. They have a scratch and dent section w/full warranty for about 1/3 the price.
Do your self a favor, before you install the new unit make sure you have your plumbing in order inside, as there is very little room to manuever on ce the new unit is in.
The other issue I had was refitting my stainless outside access door to the new unit. I did it but it took a little doing. I just could hang a white or painted access door when I have the stainless option. Dig around here and look for Overlander63, he has pictures and basic instructions for R&R listed.
It is really a pretty simple job, but plan the better part of a day to get it done.
Dave
Dave
Operation "Save Rudy" Strike Team (charter member)
You mess with the Strike Team,... you mess with the whole trailer park!!
drag'nwagon is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 13 06-28-2007 05:55 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 04:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 06:03 AM
Replace copper water lines in 61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 07:04 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 11:21 AM
