Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-08-2002, 12:24 PM   #1
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Need spring load clips for water heater door 68 GT. Andy ??
Where can I buy the clips that hold on the water heater door on a 68 Globe Trotter?
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 05-08-2002, 03:10 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Jim. Those are "DZUS" fatseners. Most aircraft shops have them. We do not, since most owners have replaced the vintage water heaters by now. Andy
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 05-08-2002, 10:05 PM   #3
Jim Clark
Jim Clark's Avatar
Thanks Andy, Bowen didn’t even know the correct name. I rebuilt my original heater after I performed a hydro test on the tank. BTW Bowen had a beautiful constructed vessel in the unit. The rebuild was to keep the original look as you don’t save enough to make it worth while. I would not advise the rebuild of a unit as old as mine unless you have a lot of experience with pressure vessels and controls as it can come back and bite you in the butt.
Thanks Jim, N5TJZ
Picture Gallery
Old 05-09-2002, 05:04 AM   #4
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
DZUS Brand fasteners
http://www.dzus-fastener.com/main.htm
-BobbyW
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 05-09-2002, 07:39 AM   #5
Jim Clark
Jim Clark's Avatar
When Andy said DZUS, the light went on. My MGA has two ¼ turn DZUS fasteners which hold on the battery cover behind the seats. I looked at the DZUS page and didn't see the exact fastener I have, may be out of production. I did see what appears to be a replacement latch handle for the rear compartment cover. Looks like an exact replacement.
Thanks Jim, N5TJZ
Picture Gallery
1/2 ton tires- load C to load E John Tires 66 08-22-2008 08:39 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
40+ year old heater 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 6 09-08-2003 06:35 PM
Roof Vent spring clips 74SovereignInt. Roof Vents, Skylights & Fans 1 07-14-2003 08:43 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
