Old 05-08-2002, 12:24 PM   #1
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Need spring load clips for water heater door 68 GT. Andy ??
Where can I buy the clips that hold on the water heater door on a 68 Globe Trotter?
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 05-08-2002, 03:10 PM   #2
Jim. Those are "DZUS" fatseners. Most aircraft shops have them. We do not, since most owners have replaced the vintage water heaters by now. Andy
Old 05-08-2002, 10:05 PM   #3
Jim Clark's Avatar
Thanks Andy, Bowen didnít even know the correct name. I rebuilt my original heater after I performed a hydro test on the tank. BTW Bowen had a beautiful constructed vessel in the unit. The rebuild was to keep the original look as you donít save enough to make it worth while. I would not advise the rebuild of a unit as old as mine unless you have a lot of experience with pressure vessels and controls as it can come back and bite you in the butt.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 05-09-2002, 05:04 AM   #4
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
DZUS Brand fasteners
http://www.dzus-fastener.com/main.htm
-BobbyW
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 05-09-2002, 07:39 AM   #5
Jim Clark's Avatar
When Andy said DZUS, the light went on. My MGA has two ľ turn DZUS fasteners which hold on the battery cover behind the seats. I looked at the DZUS page and didn't see the exact fastener I have, may be out of production. I did see what appears to be a replacement latch handle for the rear compartment cover. Looks like an exact replacement.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
40+ year old heater 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 6 09-08-2003 06:35 PM
Roof Vent spring clips 74SovereignInt. Roof Vents, Skylights & Fans 1 07-14-2003 08:43 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
