Originally Posted by SJ1
1962 Overlander has old hot water heater by Bowen. Regulator just went out.
Model G-110T. A company called Atwood took over Bowen and manufactured everything in reverse. Hence, Atwood parts do not fit the Bowen appliances.
Can anyone help?
Reglators are available.
However a 46 year old water heater is far more than just on it's last legs.
Two things.
Before you order a regulator, take the old one out. You may find that you break the tank in doing so, in which case, you will need a new water heater.
Should you manage to safely remove the regulator, there are two sizes available. Which size do you have?
If you order a regulator, you will own it, since they are not returnable. Then if you find that you need a new water heater, you will be stuck with a regulator that you cannot use.
