Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 09-22-2002, 07:37 PM   #1
silverbullet
Profile:
need plumbing map for water pump
1974 31' Intl rear bath .A couple of years ago I had a leak around my water pump (under sink area) Either I am getting old or I ws drinking when we did the work around reapair.
We somehow bypassed the water pump to solve the leak. Now I would like to put the pump back into service. The problem is that there are several copper lines and plastic hoses and I am not sure exactly what needs to go where to put the pump back into service. We are currently running fine off of city water but the pump has been disconnected and there are no open line to connect it to. What I really need is a photo or diagram so that I can have a visual reference. Any help would be gratly appreciated.
silverbullet is offline   Reply With Quote
Old 09-22-2002, 10:13 PM   #2
overlander
Guest
Profile:
Posts: n/a
try this
i was just messing around with the water pump on my 1977 overlander. this is how my trailer is set up
outside underneath the trailer there should be a steel plate with a bolt in the center of it. when you remove the bolt you can take the plate out and gain access to the oulet on the water tank and the water sensors. mine has a hose that runs from the tank to the water pump then from the water pump to the larger of the two copper lines that run toward the rear of the trailer there should be two large copper lines on is bigger on my trailer and that is the cold water supply for the kitchen sink and bathroom sink and so on. it ties into the water heater. the copper line with the the copper T's going to the sink should be the line you will tie into the outlet on your pump. my trailer has a water filter system on it aswell it is on the cold water side. aslo you should try tracing the lines back you can follow the lines on my trailer by looking underneath the sink, outside compartments, under the right side bed, rear compartment, and behind the toilet were the laundry bag is and inside the cabnet in the bathroom were the water heter is located. the water heater is labled in and out in should be cold water from the tank. by doing this you can figure out what water line does what.
yours might be set up like mine i would trace the waterlines to figure out whats what.
Water Pump David Hall Water Heaters, Filters & Pumps 8 01-12-2004 09:31 PM
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 05:35 PM
Time for a new demand H2O pump thenewkid64 Water Heaters, Filters & Pumps 14 09-26-2003 02:34 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 11:16 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
