Old 09-22-2015, 10:37 PM   #15
1968 24' Tradewind
1967 17' Caravel
Northborough , Massachusetts
Removing
Removing is rather simple as well ...
Shut off the gas and disconnect the gas tubing going to the front of the valve... (Which if you have the original valve out you have already done).
Remove all of the screws around the outside edge where it meets the AS skin. Pull out the unit... you may have to pry it a away from the skin as the sealant may make it stick to it. On the inside you (may) need to disconnect the water inlet and outlet... but if you can slide the unit out just a bit it may give you access to those screws while it is still half way in... in which case you should also be able to put back in a replacement bracket (I'm assuming one came with the valve).
If you can't access the screws with it half way out then disconnect the water lines (shut off water valves and drain tank first...) the unit should slide out
There will still be wires attached so if you have a small table that you can slide the unit out on (and the wires are long enough) then you can get it out enough to access. Cut the wires if necessary but make sure the power to them is off (12V) if you have 110v that should have a plug.
Make sure you cut the wires about in the middle where it is easy to crimp them back together with an automotive wire crimp. Mark them if they are not easily identifiable by color.
Reverse the whole process after you have finished your alteration.
Piece of cake...
cwbiii is offline   Reply With Quote
Old 09-24-2015, 08:41 AM   #16
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
It's Done
Hi Chuck,
Thanks again for your helpful advice and encouragement. This info will come in handy if or when I need to pull the water heater for replacement. In the meantime I was able to work this out. I figured out how to keep the original bracket. No replacement bracket is offered with the replacement gas valve so I modified the original. Mark, at ODM told me that one used to come with the new gas valve, but Atwood, I'm guessing, discontinued that practice a few years ago.
Anyway, Hopefully later today or tomorrow I intend to post my procedure for replacing the original with the new gas valve. I took plenty of pictures with the hope it would prove helpful to someone else.
We pullout for Albuquerque Saturday morning and our six month winter trip, so it's pretty busy around here at the moment.
Pete
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Atwood G6A-7E smelling gas. RuneM46 LP Gas, Piping, Tanks & Regulators 1 12-29-2014 07:20 PM
Water heater mdl G6A-8E mocus LP Gas, Piping, Tanks & Regulators 7 07-22-2013 11:11 AM
Water heater mdl G6A-8E mocus Water Heaters, Filters & Pumps 0 06-08-2013 06:33 PM
Atwood g6A-4E won't start stanh Water Heaters, Filters & Pumps 0 09-29-2009 02:55 PM
'93 Excella - Atwood G6A-7E binkers Water Heaters, Filters & Pumps 2 04-03-2008 09:58 AM
