Old 03-14-2009, 04:36 PM   #1
Heavily Armed
2005 30' Safari
Austin , Texas and Colorado...ish
Question My hot water heater
I was using the heater for the first time a couple days ago, and noticed that I ran out of hot water like, instantly. After knocking the icicles from various bits of my anatomy,I tried to figure out how to turn the heat up by reading The Book. I got nowhere. Would someone be kind enough to explain the process to me, assuming there is one?
Thanks in advance,
Mirthless
Mirthless is offline   Reply With Quote
Old 03-14-2009, 04:55 PM   #2
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Check your Bypass Valve
Did you or someone else winterize the system ?
My guess is that your bypass valve is closed.
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 03-14-2009, 06:34 PM   #3
B4WEDI's Avatar
2006 19' Safari SE
Check out this old thread...
Here is a little recap of the responses I received a couple years ago when I asked pretty much the same question !
http://www.airforums.com/forums/f365/how-hot-should-my-shower-be-29685.html
Nuttin' like a hot shower ..... and nuttin' like the good info and good friends you will find here on this site !
T & K
water heater
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 03:35 AM
Need New Hot Water Heater bullydogsmom Water Heaters, Filters & Pumps 11 03-01-2009 03:10 PM
Hot water heater. mrmossyone Water Heaters, Filters & Pumps 8 12-23-2007 03:26 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Hot water heater Action Water Heaters, Filters & Pumps 25 07-21-2006 07:37 PM
