Anyone have experience with the Marey instant hot water heaters sold ob eBay ($89.99)?
I was thinking of installing one on my 79 AS (Iknow they are 110v only).
__________________ 1979 Airstream Sovereign International, 31'. VIN# I31T9J0162
1992 Buick Roadmaster Wagon, 5.7L - V8, stock 5000# tow rating, posi, aux trans cooler, rear coil over shocks, 2" rear spring lift kit, flowmaster exhaust.
I looked on ebay and found this eBay: NEW INSTANT HOT TANKLESS ELECTRIC SHOWER WATER HEATER (item 330057038962 end time Dec-31-06 18:51:30 PST)
In the picture of how to install it shows it plugged into a 15 amp outlet, but in the product discription it says that it requires 30 amps. Based on the 3000 watt rating 30 amps would sound right. To install it you would have to install a seperate circut with a 30 amp breaker, heavier wires and a special outlet. Also you would not be able to use anyother electrical devices in the trailer when this was on.
We wanted to use an electric water heater, the instant water heater seems out. What about the "Tiny Titan" 2.5 gal water heaters (110v) that are sold at Lowe's Home Depot?
I don't suppose you were planning on showering with a 2.5gal heater were you?
Well it would be quick! Our gas water heater is 6 gallons, since we were remodeling we thought we might install an electric unit since we don't plan to be away from shore power. Lowes has a variety of electric water heaters from the 2.5, 6 & 10 gallon 110v heaters. I had thought about the tiny titan because it was so compact, but the 10gal would fit in one of my closets. Just thinking outloud.
Actually I had been bouncing around the idea of using a 110v 6 or 10 gallon electric water heater and using it as a water heater when connected to city water and also using it to serve as a fresh water tank by adding a on/off wall switch and tying in the 12 volt pump.
We removed the front fresh water tank when we installed new carpet and a futon.
I am not sure what you are trying to do, but here is a good article that talks about power useage and limits that you have. The 30 amps that you plug into only goes so far. You need to add up the amp draw of the electrical devices and keep that number under the 30 amp limit. RV Converters And Amp Draw (RV Camping Tips Courtesy of KOA Campgrounds)
My $0.02 is to go with the gas that should be there, you will need the closet space and the extra power draw is too much with all the other things running,
Master of Airstream
creations for less than 4 Years!
I am not sure why you would want to change out the hot water heater you currently have. We have the standard hot water heater that came with our AS and we have never had any problems. Always have it when we need it and seem to always be enough for the two of us. Between showers and doing dishes we have never run out. If its not broken..... For the few cents it costs to heat our water we are very happy.
__________________ J. Rick Cipot Sandi Gould NEUNew England Unit Airstream Life Magazine WBCCI #3411 AIR #17099
I have a few things I'm thinking. First 2 gallons isn't worth the trouble. Even with 6 gallons a shower can be short. 2, might as well just stand in the rain.
The other think I was thinking (and that's typically my first problem ), is that I would be concerned about placing a 10 gallon somewhere in the trailer that already will have a bunch of weight. RV builders do have a somewhat science to building where weight is distributed in a certain way to avoid one side getting all the heavy stuff. 10 gallons placed in the wrong area could add about 86lbs. Doesn't sound like much until you weigh in...also not sure what your axle condition is......
Well the old gas unit was only 6 gallon, so either gas or electric thats not much, (6 gallon in an electric weighs the same as 6 gallon in a gas unit).
I ordered an Ariston GL8 electric today, it hold 7.5 gallon and is 1500 watt when its heating, otherwise its off, $175.00 free delivery 6 year warranty.
I'm just venting ,but I hear people crying about weight all the time, if the frame on this raggedy trailer can't support a couple of exrtra pounds i'll melt it down and turn it into a flower pot.
I've got a 2006 - and if the standard propane water heater hasn't changed very much over the years except for the electronic ignition, then I've got to say I'm impressed with the speed mine heats it's six gallons. I full time and frankly, I leave it on all the time. During the summer I went 4 months on two 20LB tanks, and I cook on my stove top quite a lot. When I travel I turn off my tanks. It takes 5 minutes to heat up a tank of water for my shower. I have a 10 gallon electric in the office, and it takes 30 minutes to heat a new tankful if we run it out. I'd go with gas or propane just for the speed of reheating.
I notice that some campgrounds are now actually metering electricity - probably because so many RV'ers are trying to save money by using space heaters, electric water heaters, and electric frypans and crock pots. I'm guessing metering will be a big trend in future. There are even some that you swipe a credit card into before you get juice! You might not save anything going electric.
If you really need a bigger water heater, have you considered an 8 gallon propane? Buy it from salvage if you don't want to spend $$$. If you decide to resell your Airstream, a "home type" refrigerator or water heater tends to be a real turn-off for buyers. Unfortunately potential buyers can assume that the owner has "gone cheap" on maintenance and repairs. Everywhere on this forum you hear stories of plumbing "repairs" done with duct tape or garden hose, wires spliced with scrap lamp cords, silicone layered on windows, vents and seams, and similar hidden horrors. The home appliance is seen as an outward and visible sign...
With free advice, you get what you pay for I guess.
Since you have already ordered, this is academic, but did you consider the 110 v. Hot Rod which consists of a heating element which replaces your drain plug, a thermostat and a switch? This package could supplement your propane or could keep the water hot while on the grid.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
