Old 04-15-2007, 05:22 PM   #1
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
Unhappy Maiden voyage and no hot water
Hi....just returned from our maiden voyage!
We had a great first outing but had no hot water!
The burner lit but our water never got hot....luke warm at best.
Before we call the dealer tomorrow.....any suggestions? Our owners manual lists two possible pilot operation controls....White Rodgers and Robertshaw Unitrol controllers (both have a temperature lever/set temperature control.
We don't have one of these controls!!!! When we open the hot water control box it looks exactly like the "Part identification" diagram (spark ignition) in the Atwood water heater literature the dealer gave us. (this diagram doesn't show a White Rodger or Robershaw controller) HELP!
Thanks in advance for any info.....can't wait for our next outing
millvalleyca is offline   Reply With Quote
Old 04-15-2007, 06:07 PM   #2
airstreamers's Avatar
1979 28' Airstream Excella 28
southwestern , Michigan
sorry to hear about your hot water problem. have you tried going to the home page, finding the right subtopic and then using the search feature along the top of the page and entering your question? i'm sure someone here will have just the answer you're looking for, it is a great bunch of people and they are all very willing to help. congratulations on your maiden voyage. i'm sure it will be the first of many! welcome
airstreamers is offline   Reply With Quote
Old 04-15-2007, 06:28 PM   #3
ScottW's Avatar
Hernando , Mississippi
I hate to ask the question...but I've done it several times myself....What was the outside temperature and how long did you leave the water heater on before you checked the temperature. Don't mean to insult your intelligence, but, been there, done that.
Rgds,
Scott
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 04-15-2007, 06:54 PM   #4
Hey ScottW
Just tested the hot water...it's 5:45 pm the temp outside is 68. (this morning it was 37)
I pushed the igniter button inside...light went on...burner turned on.....light went off....burner still on....blue flame and hot.....stayed on for about 5 minutes. No hot water...just luke warm
Old 04-15-2007, 08:11 PM   #5
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
if yours is the same as mine .There is a safety thermal fuse that melted due to a spider web causing a porpane build up and flash fire. Does it come back on again?
How about on electric?
Michelle TAC MT-0
Sarah, Snowball
Old 04-15-2007, 08:24 PM   #6
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
After you hooked up, did you run the hot water spigots to make sure the tank was full?
Did you check the water heater bypass valve thats used in winterization?
Did you check the shower mix valve was off and not rely on just the shower head off setting?
-Tim
theVAP - Airstream Podcast
Old 04-15-2007, 08:30 PM   #7
we only have propane no electric.
just tried it again.....burner was on for 12 minutes.....water ran cold....then HOT for a sec and then barely warm. One thing i noticed with the flame...it sputters like being blown by wind eventhough it's not windy right now. I dread having to take our baby to the dealer because it's a two hour drive. And so far this is the only problem with our new Binki3
Old 04-15-2007, 08:36 PM   #8
Keymar , Maryland
Sound like the thermo sensor is causing a premature shutdown.
Check all the things Tim said.
Looks like a visit to a dealer is in order. Call the factory tomorrow morning ask for tech support. IF that does not work ask them if you can take it to a local that knows about your heater.
Cool glad you found it.. Simple but annoying.
Michelle TAC MT-0
Sarah, Snowball
Old 04-15-2007, 08:44 PM   #9
THANK YOU thank you thank you
Hey Tim and the other people on this forum.
HOT water! The bypass valve was open....closed it and instant hot water!
Where do I send the check toTim?
Can't wait for our second voyage.....
We are truly newbies having a great time.
Thanks again!
Old 04-15-2007, 08:44 PM   #10
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Ours did that too.....unless there is a major problem, it's most likely the bypass valve area. Recheck the valves and you may find as I did that the three valves are not correct. Reading your post was the exact spitting image of what I found when I hopped in the shower after the water heater finished heating the water. Upon setting the three valves correctly, it was hot and stayed hot until I chewed up all 6 gallons! I'd bet real money the valves aren't closed or opened right, at least one of the three isn't!
Old 04-15-2007, 08:46 PM   #11
Aluminut
2004 25' Safari
. , Illinois
HA! Just finished the post and read your post that you posted at the same time I posted mine.....glad you found it!
Old 04-15-2007, 08:56 PM   #12
wanderer1's Avatar
1986 Argosy
ocala , Florida
Images: 24
hello millvalley,first,did you fill l.p. tanks.2nd are l.p. valves fully open.ok,if that stuffs alright,it takes little wind blowing to make your flame flicker.Also leave the w/h switch on the whole time you need hot water.The light is only on while lighting,then goes off,pilot is still lit.It will take apx. 30 minutes + or - ,with the w/h switch on for the water to get hot.Hope that helps you...
wanderer1 is offline   Reply With Quote
Old 04-15-2007, 08:57 PM   #13
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Cool, glad you found it!
-Tim
Old 04-15-2007, 09:03 PM   #14
wanderer1's Avatar
1986 Argosy
ocala , Florida
Images: 24
Opps,too late
